Willis's Garage Cleanout! :yes:
Location; Sydney NSW (Western Suburbs)
Ok so i have just sold my skyline. Trying to clear out some space. Send any offers through via PM.
Regards, please don't msg me asking if i have thing's that are not listed. Thanks.
Engine / Driveline;
RB20DET Engine (no turbo, no coilpacks, no power steering pump, no aircon compressor and no starter motor) comp test 130 PSI across cold, removed for RB25 conversion. - $500
RB20DET Gearbox (average condition, second gear synchro is pretty shot it's fine when rev matching though.. gearbox whine in 1st and 2nd gear's) removed for RB25 conversion, includes RB20 Clutch Slave - $300
RB20DET Driveshaft (good condition) removed for RB25 conversion - $150
RB20DET / 25 S1 Throttle Position Sensor - $40
RB20DET Radiator + Shroud - No leaks, no corrosion, removed for Aluminium Radiator Upgrade - $100
RB20 Clutch Master Cylinder - $60
RB20 Clutch Slave Cylinder - $20
Exterior;
Front bar as pictured (pretty average condition, would suit drift pig) - $40
LH + RH Doors (Gunmetal Grey), average condition, includes windows and everything else found in the door, includes door skins - $150
LH + RH Guards in average condition (Gunmetal Grey)- $150
R32 GTR N1 Headlights, Immaculate - $250 pair (no mount for grill, can be bought from nissan for cheap..)
post-75263-0-47983800-1369092612_thumb.jpgpost-75263-0-82795200-1369092620_thumb.jpgpost-75263-0-81054900-1369092629_thumb.jpgpost-75263-0-02744200-1369092638_thumb.jpg
Exhaust;
RB26 FRONT PIPES (twin 2.5" inlets to 3" rear) contact damage with ground - $50
3" Jasma approved cat-back suit R32, includes catalytic converter - $150
Suspension;
HCR32 OEM Camber Arms - $50
HCR32 OEM Castor Arms - $50
Driftworks HICAS Lockout Kit, BYO bolt's etc - $150
GK tech adjustable castor arms V2 suit s13/180/r32/a31, billet 7075-T6 aluminium construction BRAND NEW IN BOX - $120 (rrp 150)
Braided Brake Lines - $60
Driftworks Solid Subframe Risers (new in box) - $80
Interior;
Skyline Door Trims (kick panels), both in good condition - $20 pair
Sparco Pedals + OEM Pedal Box's, Clutch, Accelerator and Brake - $120
R32 GTR NISMO CLUSTER 260kph / 10k rpm ODO 78568 - $300
R32 Ash Tray - $30
Apexi Pen Turbo Timer - $50
Drift Button GK TECH - $10
Wheels;
Work VS-MX 17 x 8 +22 and 17 x 9 +22 pcd 5x114.3 & 4x114.3 17 x 8 +22. No buckles, wheels have rash as pictured. These are genuine 3 piece items, i bought them with the intention to rebuild with larger lips. The front's require spacers to clear 32 GTR brakes.
The 8's come wrapped in 205/40r17 as pictured. The rears are in similar condition, have more dish and no tyres. - $1200 ono
post-75263-0-37142700-1369093212_thumb.jpgpost-75263-0-80237600-1369093219_thumb.jpgpost-75263-0-96142600-1369093227_thumb.jpgpost-75263-0-18505100-1369094889_thumb.jpgpost-75263-0-22957500-1369094890_thumb.jpg
Kosei 17 x 8 +38 and 17 x 9 +38 wrapped in 235/45r17 & 255/40r17 Bridgestone Adrenaline's (tyres are down to wear markers, camber worn, wheels have rash, structurally sound) - $700
post-75263-0-23864400-1369093235_thumb.jpgpost-75263-0-79649800-1369093241_thumb.jpgpost-75263-0-89136700-1369093249_thumb.jpgpost-75263-0-49608100-1369093472_thumb.jpgpost-75263-0-75960900-1369094884_thumb.jpgpost-75263-0-15200700-1369094886_thumb.jpg
Rays Gram Lights 17 x 9.5 + 36 PAIR ONLY(tyres are dead) - $400
Random parts;
Trust Front Mount I/C NO PIPING - $150
R32 GTR Resistor Pack (to run 32 GTR Injectors on a RB20) homemade - $50
SCA Engine Crane as new! used once then stored in garage! - $250
K&N Intake Pod Filters suit RB26 - $50
S13 / 180SX SR20 Oil feed hardline, not leaking bought as a fix for my old leaking one - $30
Thanks! :)
Willis.
Edited by Willis
https://www.sau.com.au/forums/topic/425623-williss-garage-cleanout/
are those N1 genuine? i cant see the mount for the grill
i'll take the trust cooler
send me your number over pm
thanks
PM Sent.
empty your inbox buddy,
i'll take the front guards off your hands
Inbox emptied.
Sounds good, PM Sent.
Hey dude, I'm after a stock gear shift lever for a rb20, got one?
Cheers
Tom
Hey buddy, i don't have one. As i stated in the thread;
Interested in parting out the doors?
It depends what you want and how many $ you will pay. Maybe just offer me on the doors?
Part them yourself? :)
Willis.
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
    • I stick with Shannons through inertia and because they had to accept some things about insuring my car that they didn't really want to, but had to when their parent absorbed my previous insurer and forced me into their portfolio. I might struggle to convince anyone else to take that on for the moment.
    • There's no good RB25s lying around either. A blown RB20 is a good time to build it to take 35psi and give it a twin-charge using a nice screw compressor and a big fat turbo. Blower makes it act like a 3L and turbo makes that act like a 6L.
    • Reckon it'll be OK after 5 years? Running RB20s aren't $1k/free to good home like they used to be! Some might say a blown RB20 is a good time to move onto RB25 though...
    • You may well find that there is a big air bubble in there and plenty more coolant will be swallowed once it starts. So keep the bottle handy. If you can roll it back and forth, you can make the pistons go up and down a bit by putting it in 3rd or 4th and giving it a shove.
