This is Rebecca, lifts in the 60kg class, still a Junior, will be hard to beat at Nats. Puts most guys to shame, she will squat 140kg at Nats, shes already deadlifted 150kg in competition and benches 70kg+
In this prep, 17yo Conor has squatted 240kg, benched 120kg and deadlifted 240kg, weighing 87-88kg
Zoran has gone 260/155/300
Jack has gone 300/200/300
Max has gone 265/165/255
Martin has gone 255/160/270
Three girls have benched 70kg+
Heidi 72.5kg
Sussy 75kg
Nina 77.5kg
I currently have 6 lifters who can squat 250kg, bench 150kg and deadlift 250kg
Max
Jack
Daniel
Zoran
Martin
Spiros
I have others who bench 150kg or deadlift 250kg, but only these 6 can hit those marks on all 3 lifts, very balanced lifters.
Harry deadlifts 260kg but only squats 220kg and benches 120kg
Stelian benches 160kg but only squats 215kg and deadlifts 230kg
Alex can bench 155kg but only squats 180kg and deadlifts 220kg
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
