Hi guys I have spent 3 hours researching this but can't find it. My car is at tuner after full engine , gearbox and turbo change as well as ecu, anyway hicas light is on which I wasn't too worried about but now when ignition is on there is an audible pulsing sound coming from the engine bay and its affecting my flex fuel sensor. I really didn't want to go down lock bar route due to defecting etc, could the adaptronic ecu be causing this, have I plugged wrong connection in on the solonoid as in mixed them up? Or could it be bleeding issue? With each pulse the light flickers and as I said it can be clearly heard. The power steer pump was off completely during engine removal btw.
Thanks guys
https://www.sau.com.au/forums/topic/425655-hicas-solonoid/
i have lock out bar on mine, though now i have the problem of the hicas light flashing with the noise, and it also moves the steeering left to right a little bit by itself... is there somewhere else i have to unplug,remove fuse or something. was fitted by a mechanic though maybe forgot to discoonect something
https://www.sau.com.au/forums/topic/425655-hicas-solonoid/#findComment-6867614
