This looks like the closest match; but would rely on the key blank being correct.
Then it would be a matter of transplanting the transponder from your OEM key into the shell.
http://www.ebay.com.au/itm/Nissan-2-Button-Remote-Flip-Key-Shell-Case-MICRA-PATHFINDER-NAVARA-350Z-/261137460205?pt=AU_Car_Parts_Accessories&hash=item3ccd016bed&_uhb=1
It's not a huge expense; let us know how you get on!
I boned the OEM Central Locking key/remote when i had my immobiliser fitted; and the size of the OEM thing shit me to tears.
My normal sized key+tiny Autowatch fob is a much better proposition in the pocket.
https://www.sau.com.au/forums/topic/425664-flip-key-m35/#findComment-6860396
There's no way to put a keyring on that one you linked Dale. So you'd have a rectangular key fob (nearly as big as the original key anyway, lol) floating around separate to everything else. Still a good way of refreshing the old keys though I suppose.
https://www.sau.com.au/forums/topic/425664-flip-key-m35/#findComment-6860429
I would rather a healthy power curve than a ricer push button start. :P
Glad we don't have a ricer start button then. Still gotta turn the ignition but without the key in it.
Hey, there are lots of things I'd rather aswell, like not having to replace tubz after 100k km or carrying around AFM because paranoid :P.
https://www.sau.com.au/forums/topic/425664-flip-key-m35/#findComment-6862061
As far as I know none of the turbo Stagea's had transponders in the key, so it should be fairly straight forward. I can't stand the Audi flip key personally.
I'm not very good a tech stuff but I'll give it a go when I get some time..Why don't you like the Audi keys?
https://www.sau.com.au/forums/topic/425664-flip-key-m35/#findComment-6869458
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
