hey guys, i've got a r34 GT-T. pretty much totally stock. I've had it for almost 2 years and haven't had a single problem. but just yesterday all of a sudden it wouldn't start. I drove it fine and about an hour later tried driving it again and it wont start at all.
The car sounds like its about to start so its not battery related, but it simply doesn't fire up. the NRMA guy said there isn't enough pressure in the fuel line and when he sprayed fuel from a can into the engine the car sounded like it wanted to start but simply couldnt.
I really need the car fixed ASAP. Is this a common problem? I am wondering would this have caused my spark plugs to get fouled also? as i tried starting it for a fairly long while.
And is it likely to be the fuel pump? is there a method to test what is actually wrong?
Thanks heaps.
Sounds like a fuel pump, easy way to check is get a test light and make sure your getting power to it first. Or if your really lazy get a friend to turn the key to the 'on position' while you have your head in the boot, listening for a slight hum from the pump. As it should prime the fuel rail before start up.
If no hum more than likely it will be the fuel pump. Bosch do a universal pump that fits in the housing perfectly, otherwise Walbro do a few reasonably priced units for standard replacement. Just call lube mobile out and get them to do it in your driveway. They did mine, only took the guy bout an hour to diagnose, get parts and fit it!
Edited by Aazzy
Your fuel pump is likely on its way out. Its an easy method to replace it. Unplug the fuel line from the pump and puy it into a bucket then start the car. If no or little fuel.comes out the pump is gone. Make sure the pump is getting power. Might be a fuse. They screw up because they wear out, seize, sick up dirt etc. Its an old compoment. Easy to fix.
oh okay. lube mobile sounds expensive probably give it a go myself.
doubt its the battery because it was tested with the 12v source the nrma have
If you have no idea about anything, paying someone an hour labour to fix the problem is not expensive. Or you can f**k around for ages and make a ness of it yourself
rather do things myself on the car, so at least i can learn it. i mean its just a fuel pump, shouldn't be too hard to replace.
anyways, yeah just looking for general suggestions on what it could be if it's not the fuel pump.
and a quick question, when i turn the key twice so the car and audio n all that is on, but im not holding the key in igititon to start it. at that time, should the fuel pump immediately start pumping fuel? even though the engine isn't on? how does that part work exactly?
okay so i've done a lot of searching around and think the best/cheapest replacement for the car is the bosch 040 intank fuel pump? its costing $210 at just jap.
My car is pretty much stock and i doubt ill be upgrading it heavily any time soon, so i dont really need a high flow pump, is the stock oem part cheaper? what is the best replacement pump/cheapest i should use?
and its an in tank pump, not external inline one?
The Walbro needs to be wired to the battery through a relay and fuse, there is a 'how to' around if you search.
it doesnt "need" to be does it?...it just wont run at full potential if its not...but it will run fine as a replacement pump...
unless you are planning power mods for now just buy one from one of the many cars being wrecked...cost nothing...problem solved
I have seen failures and also car's stalling/running shit when wired to the factory wiring, they are supposed to run on 12V minimum, any less can cause the windings to burn out or pressure fluctuations.
Nismo/Tomei pumps seem to run fine on the lower voltage, as do stock pumps. Most aftermarket pumps require the wiring mod.
thanks for all the help guys. changed the fuel filter and the fuel pump. the old pump was not working at all.
i hooked this one up with stock voltage as the relay system is a bit out of my understand (electronics). but it seems to run fine, at least as a stock replacement. might be the placebo but i actually feel like there is a slight performance increase.
Thanks again guys. :)
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
