So here's one I havn't seen before,
Multiple gauge failure on the standard R33 GTST S1 dash cluster,
No boost gauge (Has aftermarket fitted and plumbing is still attached to standard as well as aftermarket)
No oil pressure gauge (again has aftermarket fitted but Havn't checked connection's to standard)
No fuel reading (Has Hi flow fuel pump fitted)
Any opinions on whether it could be? Possibly one single cause or just a case of 3 seperate causes?
I have checked to make shure all plugs are plugged into the dash and all ok. Obviously considering I have the after market gauges working the fuel gauge is currently my biggest priority, but dont want to pull the fuel sender out if it could possibly be a much simpler issue.
Also not car is not running the factory ECU, It's running purley on a Haltech waying up wether this too could be a cause of the problem.
Otherwise no other auto electrical issues.
Any help would be appreciated.
https://www.sau.com.au/forums/topic/425674-multiple-gauge-failures/
