I will be needing to get a decent wheel alignment for my R34 GTT and there are no decent wheel alignment places in Perth that I can drop the car off without telling them the exact specs I want it at. Last time I dropped it off to a well known company they set it up as a Nissan Bluebird.
I was wondering if you had any basic settings that you would use to start off with on a street car that was to be taken round a track. Any help would be greatly affected.
STOCK R34 GTT SETTINGS
Front Camber: -1.00
Front Caster: 7.00
Front Toe: 0.00
Rear Camber: -0.5
Rear Toe: 2.00mm in on each side
SAI: 9.00
I was thinking something along the lines of
Front Camber: -1.5
Front Caster: 5.5DEG
Front Toe: 1.5-2MM out TOTAL
Rear Camber:-1
Rear Toe: 1MM IN EACH
It has the old SYDNEYKID suspension setup. IE Bilstein shocks, whiteline springs, whiteline adjustable sway bars. JIC adjustable caster arms (front), Cusco adjustable toe arms (rear), Hicas eliminated & adjustable camber bushs in the front.
Regards
Chris
https://www.sau.com.au/forums/topic/425681-r34-wheel-alignment-specs/
Your suggested values are probably fine. I wouldn't back off the front caster at all, and I wouldn't add any more neg camber at the front if you're going to spend most of your time driving on the street. I wouldn't make it toe out either. Zero toe is probably the wisest for a streeter.
At the rear, no more neg camber than you suggest, preferably a little less.
cheers
  • 11 years later...
cheers
When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms and my car is lowered a bit (front end is basically stock after I change to those nismo bushes)
Edited by silviaz
Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters.
You can only wind so master caster at the front, and ~7° is fine.
You won't have choice of front camber.
If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there.
So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
Bit confused as what the answer to my question is? I guess with the front the only thing they can adjust is the tie rods?
Well, unless you are prepared to do it yourself, or to pay someone for a lot of labour, you don't want to move the rear camber around much at all. Close to stock length on the rear upper arms (both the RUCAs and the tension arms) will minimise the addition of bump steer. That means you should probably be satisifed with whatever neg camber you end up with as a result of it being lowered, and not try to dial too much of it out. Dialling it out by making big changes to the RUCA length will require effort put into tuning the length of the tension arms.
And, apart from front caster and toe at both ends.....that's all there is to talk about. So, yes, toe settings, pretty much.
  • Like 1
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to moth things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
    • Think ill be going hunting for bad earths and might just replace the alternator for shits n gigs as its an LS alternator but only about 5 years old with very minimal use in that 5 years.
