Ok so I have a built rb26 running a nitto oil pump with all the usual mods. I have just fitted a new pair of -5 turbos and under the instruction of the distributor I did not fit an oil restrictor to the oil feed line. The oil feed line is -4 braided and I use a 90deg fitting into the turbo not a banjo bolt. After starting the car and running it for 10 mins there is a slight bit of smoke out the exhaust on idle which increases greatly as the rpm rises. I believe this to be too much oil pressure to the turbos. I have been tossing between fitting an inline oil pressure regulator which is made by peterson. I like this as I have control at a valve like setup. Or inline restrictors.
I know the inline oil restrictors is tried and tested, but is there a reason people don't use a valve like setup? If I run a restrictor does it need to be fitted at the turbo connection or can I fit it at the block?
Any help would be appreciated
https://www.sau.com.au/forums/topic/425683-rb26-5-oil-feed/
hurry and fit the oil restrictor, you can damage the turbo very quickly...
best to put it on the turbo, something like this.
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-OIL-021&Category_Code=
https://www.sau.com.au/forums/topic/425683-rb26-5-oil-feed/#findComment-6864632
I spoke to garrett and countless tuners and shops etc most don't use restrictors and I think none use them in stock lines , problem is that 1mm is too small and there have been cases of damaging the bearings due to lack of oil so damned if u do or don't, every engine is different but 1.5mm I think is about right size but as std banjo is about 2.5mm hardly worth the effort as with such a large oil return it really shouldn't be a problem . Interestingly the ppl who rebuilt my turbos explained how the seals work to me and it seems many ppl have bad catch can setups that put pressure on seals and somehow cause them to move due to pressure differential and they leak. Anyway best of luck with this one, my best comment came from crd who said we don't sell restrictors but what we do is something we keep close to our chest which is fair enough I guess.
https://www.sau.com.au/forums/topic/425683-rb26-5-oil-feed/#findComment-6865136
  • 1 month later...
Hey any further info on this Shazz? Sorry to hijack but I'm interested to see how you got on as I'm having the same problems as you and a few others as well.
Basically built 26, usual mods new -5's originally with trust oil pump which turned out to be a copy causing high oil pressure. Found out after I had already fitted 1mm oil restrictors to the banjo bolts and then removed the front turbo (only one leaking) and sent back to be inspected all came back clear so engine out new N1 pump with billet gears oil pressure solved.
Had it in to get tuned last Thursday and apparently it's still smoking oil smoke out the exhaust when it comes on boost. Not doing it on idle like it was with the old oil pump just once the turbos are working. Pulling my f**king hair out because this has been going on for 9 months now and EVERYTHING is brand new. Only thing that's not new is the stock oil feeds. Haven't had a chance to pull anything apart again but the mechanic pulled the intakes off and there's no oil in the front housings so he thinks rear turbo oil seals.
I was wondering as an absolute long shot whether one of the hard lines is blocked causing all the oil to feed to the one turbo pushing it past the seal. Got no idea if this is even possible but ever since I bought the car and with 3 different sets of turbo's (2 were 2nd hand stock sets) I've had oil smoke out the exhaust and the only original thing on there other than the block and head which have both been reco'd is the oil and water feeds.
Gonna pull the y pipe off and see if it's one or both of the turbo's leaking and which one (was the front last time) and also pull the oil feeds off and test them.
Anyway just wanted to see if you had any luck with yours.
Also Guilt-toy mentioned you can damage your turbo quickly with high oil pressure could this be my problem? Car has done exactly 0kms other than what it did on the dyno the other day.
https://www.sau.com.au/forums/topic/425683-rb26-5-oil-feed/#findComment-6926862
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
