450Hp not kw obviously haha
You really are terrible at this, work with us - read our answers and answer the questions you are asked properly, I have no idea why some of us are still bothering. What fuel will you be running?
Are you bloody stupid mate, or a troll... seriously?
Grow a brain, read what people are asking you to do.
We cannot give you the response you're after if you dont provide details with what you want?
After asking numerous times we finally figure out you want 450hp at the wheels... When do you want boost to come on? Whats your budget for supporting mods? (injectors, manifold, wastegate, ecu etc etc)? What fuel as stated above?
Theres more than just hurr durr i want some power but respone bruzz... everyone has different interpretations of these words, we need to know YOURS in DETAIL.
  • 1 year later...
f**k me is this guy a muppet or what , please forgive my french , risking warning points here , but give up boys , this muppets not helping one bit , try a f**king hair dryer a breville at that , you might get 450 what evers, that's got power response and run it on 240 volt that'll do the trick what ever that may be
okay thinking about it rather than abuse i thought an example might educate, so here goes, hey guys looking for some advice , should i stick with twins or do single turbo change, im running e85 ,looking for 500 hp wanting best response possible , maybe kick in at 4000 rpm, my mods are endless i want to go all the way , throwing money at it like i'm a millionaire, got nitto stroker kit going in , 2.8, got oversized oil pump, apexi hardpipes nismo intercooler, so on so on plazaman plenum, tomei procams 270 deg 11.5 lift over sized valves , 1000 cc injectors ,power fc d jetro ,and giving it to grandma for her daily , any suggestions on turbos please
I have an unopened engine using factory cams, and factory plenum. Its using a Brae high mount with a 50mm external gate with one of my ATR43G4SAT turbochargers on E85 fuel. This is probably as close as you can get towards factory T25's response while been able to reach the 400awkws goal. For 500awhp / 373awkws, it was reached at 21psi. Power readings corresponding to other boost levels of my car can be found on the RB26 dyno section:
http://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page-26#entry7529745
Blues: ATR43G4SAT
Purple: Factory twin T25s
Anyone got any experience Pro-boost stuff.
I am considering the GT35 orTo4z T4 bush bearing kit, manifold and wastegate.
The rotary guys don't mind them.
Any fair and truthful info would be great.
