Hey Guys/Girls
So last week I was checking out the exhaust setup on my R34 and it was just a simple HKS Catback, since I had ordered a turbotech boost controller I decided it would be a good idea to help the car breath better and open up the rest so I went ahead and purchased a KLS stainless steel turbo-cat dump pipe from Ebay. $235 posted. - http://www.ebay.com.au/itm/230881892110?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
There are numerous options ranging from $150 up to 600+ when purchasing this however I liked this one because a) it was reasonably priced for a stainless steel one and b) it had the 2-1 flow from at the top of the flange. I got it installed into my car today (another $200) and I wanted to share so you guys can make informed decisions on your setups.
As the guys at the shop told me the dump pipe normally adds a slight increase in boost response due to the more open flow and bolting directly onto the stock turbo this is a good for those not wanting to run an aftermarket/custom setup. On the drive home I didn't notice any power difference at all, and the sound still remains the same. The guys told me I was losing about 40% flow due to my OEM cat been nearly stuffed so with that in mind I have found a Xforce stainless steel for $195 posted. Will be ordering next paycheque to complete my full system! Hopefully, combining that with my new dump pipe it will see a slight increase, I do feel allot happier running 10psi with a much more open system. I will post results from my new cat when I get my hands on it, hopefully in a week or so....
It should be noted that the dump pipe fits fine but came up just short so the guys had to make a small bend to connect to the cat, otherwise is all ok with the OXY sensor etc. If I get a chance ill throw some pictures up tomorrow.
https://www.sau.com.au/forums/topic/425697-r34-gt-t-dump-pipe-install-feedback/
Be aware that if you do not have programmable management that the boost will possibly rise when you change the cat and the car will probably go into R&R and be slow. You'll probably need to dial back the boost to get it working again.
Nah shouldn't rise when its on a manual boost controller and running 10psi, all I'm doing is freeing it up a bit, not really enough to worry the standard ecu. Its running very nicely as it is
Yeah thats ok, by freeing up the exhausts it'd be lucky to rise close to 1psi if that. Was running 7 with the catback and no MBC. Will post results when I throw the cat in and see how it responds
What are you basing that statement on about the boost rise? I'm going to assume not from experience....... Anyway, you will soon find out.
Mine rose to 12psi when I did the full turbo back exhaust. It definitely rises when you get it all breathing well.
Ran it today on the stock gauge and it was about 13psi so I've brought it back to about 10-11 according to stock gauge. I have a turbo smart gauge I could test with as well but got tired of trying to find a place in the firewall to run a hose through. If I get a tune the only mods I have are the exhaust and MBC so what would the advantage be? And I'm not really up for an expensive aftermarket computer as my next mods down the track will be a front mount and that's probably it (daily driver). Can you tune the stock ECU and do I really need to?
Yeah I have they plug into stock ecu yeah like a piggyback? What does an average tune cost with one of those?
By biggest concern is the tune going bad, car getting idling problems, air cond not working properly or something factory not working because of aftermarket ecu.
Edited by neopowered34
Sounds like my next mod is gonna be a Nistune! What about knock sensor, I was reading a forum before saying that programmable ecu's can cause the knock sensor to fail, are there ANY downsides to putting one in that will affect the little things in my car from operating as per factory spec? And what about my inkectors they are only stock
it's also cheap, $550 with a software licence and instalation, 1k with a tune but nil licence, how much is Link, Power FC, Adaptronic?
There's a guy in Melbourne offering Supply + Fit + Tune for R34 $840!! Too bad I'm in QLD :(
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
