Hey Guys/Girls
So last week I was checking out the exhaust setup on my R34 and it was just a simple HKS Catback, since I had ordered a turbotech boost controller I decided it would be a good idea to help the car breath better and open up the rest so I went ahead and purchased a KLS stainless steel turbo-cat dump pipe from Ebay. $235 posted. - http://www.ebay.com.au/itm/230881892110?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
There are numerous options ranging from $150 up to 600+ when purchasing this however I liked this one because a) it was reasonably priced for a stainless steel one and b) it had the 2-1 flow from at the top of the flange. I got it installed into my car today (another $200) and I wanted to share so you guys can make informed decisions on your setups.
As the guys at the shop told me the dump pipe normally adds a slight increase in boost response due to the more open flow and bolting directly onto the stock turbo this is a good for those not wanting to run an aftermarket/custom setup. On the drive home I didn't notice any power difference at all, and the sound still remains the same. The guys told me I was losing about 40% flow due to my OEM cat been nearly stuffed so with that in mind I have found a Xforce stainless steel for $195 posted. Will be ordering next paycheque to complete my full system! Hopefully, combining that with my new dump pipe it will see a slight increase, I do feel allot happier running 10psi with a much more open system. I will post results from my new cat when I get my hands on it, hopefully in a week or so....
It should be noted that the dump pipe fits fine but came up just short so the guys had to make a small bend to connect to the cat, otherwise is all ok with the OXY sensor etc. If I get a chance ill throw some pictures up tomorrow.
https://www.sau.com.au/forums/topic/425697-r34-gt-t-dump-pipe-install-feedback/
Be aware that if you do not have programmable management that the boost will possibly rise when you change the cat and the car will probably go into R&R and be slow. You'll probably need to dial back the boost to get it working again.
Nah shouldn't rise when its on a manual boost controller and running 10psi, all I'm doing is freeing it up a bit, not really enough to worry the standard ecu. Its running very nicely as it is
Yeah thats ok, by freeing up the exhausts it'd be lucky to rise close to 1psi if that. Was running 7 with the catback and no MBC. Will post results when I throw the cat in and see how it responds
What are you basing that statement on about the boost rise? I'm going to assume not from experience....... Anyway, you will soon find out.
Mine rose to 12psi when I did the full turbo back exhaust. It definitely rises when you get it all breathing well.
Ran it today on the stock gauge and it was about 13psi so I've brought it back to about 10-11 according to stock gauge. I have a turbo smart gauge I could test with as well but got tired of trying to find a place in the firewall to run a hose through. If I get a tune the only mods I have are the exhaust and MBC so what would the advantage be? And I'm not really up for an expensive aftermarket computer as my next mods down the track will be a front mount and that's probably it (daily driver). Can you tune the stock ECU and do I really need to?
Yeah I have they plug into stock ecu yeah like a piggyback? What does an average tune cost with one of those?
By biggest concern is the tune going bad, car getting idling problems, air cond not working properly or something factory not working because of aftermarket ecu.
Edited by neopowered34
Sounds like my next mod is gonna be a Nistune! What about knock sensor, I was reading a forum before saying that programmable ecu's can cause the knock sensor to fail, are there ANY downsides to putting one in that will affect the little things in my car from operating as per factory spec? And what about my inkectors they are only stock
it's also cheap, $550 with a software licence and instalation, 1k with a tune but nil licence, how much is Link, Power FC, Adaptronic?
There's a guy in Melbourne offering Supply + Fit + Tune for R34 $840!! Too bad I'm in QLD :(
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
