Ok I'm at work trying to get the pulley off and it's seized on and we want to fine a way to get it off without having to cut it off
We have heater it soaked in in crc cleaned all teh rust leavered it and everything we can think of. It's on there hard
If you can, get a puller in behind the sprocket and push off of the crank snout. Otherwise cut it and then by a new one before you wreck the crank/oil pump.
Genuine-Nissan-Crankshaft-Sprocket-Kit-N
http://www.kudosmotorsports.com/catalog/nissan-crankshaft-sprocket-kit-genuine-nissan-rb20et-rb20det-rb25det-rb30et-p-1197.html
i had this problem once before
i used a skinny crowbar on the back of the spocket and GENTLY levered it off , dont apply pressure on the one spot ie move the bar around and lever off DIFFERENT POINTS of the spocket
We got it. Had to bit the bullet and cut it off
We used a dye grinder with a cutting wheel and then cold chisel one hit with the chisel and it split and off it came
Now to get the key out. It's all rusted and siezed aswell
We needed to take both out to clean. So this didn't happen again
The front one the boss hit with the cutting wheel so we will order 2 new ones a new pulley and plates. So we will just get the one from kudos :P
    • There's more than one way to skin that cat, and most of the sump Maatouks have done will be GTR sumps. They are HUGE in GTR drag racing here.
    • Yeah...I always start at the shift solenoids, because there's only a few reasons these will spook into limp mode, and bad shift solenoids is one ~ the other can be the shift control module (if you have steering wheel shift buttons)...it's easier to eliminate the solenoids first.
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
