Ok I'm at work trying to get the pulley off and it's seized on and we want to fine a way to get it off without having to cut it off
We have heater it soaked in in crc cleaned all teh rust leavered it and everything we can think of. It's on there hard
If you can, get a puller in behind the sprocket and push off of the crank snout. Otherwise cut it and then by a new one before you wreck the crank/oil pump.
Genuine-Nissan-Crankshaft-Sprocket-Kit-N
http://www.kudosmotorsports.com/catalog/nissan-crankshaft-sprocket-kit-genuine-nissan-rb20et-rb20det-rb25det-rb30et-p-1197.html
i had this problem once before
i used a skinny crowbar on the back of the spocket and GENTLY levered it off , dont apply pressure on the one spot ie move the bar around and lever off DIFFERENT POINTS of the spocket
We got it. Had to bit the bullet and cut it off
We used a dye grinder with a cutting wheel and then cold chisel one hit with the chisel and it split and off it came
Now to get the key out. It's all rusted and siezed aswell
We needed to take both out to clean. So this didn't happen again
The front one the boss hit with the cutting wheel so we will order 2 new ones a new pulley and plates. So we will just get the one from kudos :P
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
