Ok I'm at work trying to get the pulley off and it's seized on and we want to fine a way to get it off without having to cut it off
We have heater it soaked in in crc cleaned all teh rust leavered it and everything we can think of. It's on there hard
If you can, get a puller in behind the sprocket and push off of the crank snout. Otherwise cut it and then by a new one before you wreck the crank/oil pump.
Genuine-Nissan-Crankshaft-Sprocket-Kit-N
http://www.kudosmotorsports.com/catalog/nissan-crankshaft-sprocket-kit-genuine-nissan-rb20et-rb20det-rb25det-rb30et-p-1197.html
i had this problem once before
i used a skinny crowbar on the back of the spocket and GENTLY levered it off , dont apply pressure on the one spot ie move the bar around and lever off DIFFERENT POINTS of the spocket
We got it. Had to bit the bullet and cut it off
We used a dye grinder with a cutting wheel and then cold chisel one hit with the chisel and it split and off it came
Now to get the key out. It's all rusted and siezed aswell
We needed to take both out to clean. So this didn't happen again
The front one the boss hit with the cutting wheel so we will order 2 new ones a new pulley and plates. So we will just get the one from kudos :P
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
    • Even though I have some pretty good (brand) ratchet ringies, I avoid using them to break open tight bolts. A broken ratchet is very annoying.
