One of a kind 240z. This car has been built with no expenses spared since 2004 from ground up. If your into the classic JDM cars I'm sure a car like this would be on your list of affordable cars to experience once in your life time.
384208_10151011967437330_1539298151_n.jp
390496_10151011952172330_2120652015_n.jp
Engine:
2.4L rebuilt, balanced and bored to 2.8L with mild cam.(N42 block with E88 Head)
Triple 40mm webbers set up by Stewart Wilkins Racing
SWR extractors
Electronic Ignition
Dyno'd at approx 116KW at wheels (weighs 1060kg)
Running gear:
Arizona coilovers revalved bilstein shocks from Heismans suspension
4 pot Wilwood Brakes Front
Disc brakes Rear
Stock front n rear sway bar
Rose joint front sway bar end links
Rose joint front caster rods
Rose joint front adjustable control arms
Rose joint rear adjustable control arms
Front top strut brace
Solid Diff mount
Complete bushing replacement of all bush points from steering busings to rear diff moustache bar.
New engine and gear box mounts
OSgiken LSD
Stewart Wilkins 5 speed with 1:1 fifth gear ratio (his now selling them for $12,000 per box). Dog leg 1st gear.
Wheels:
Original Watanabe's 15" by 8"
Toyo R888 semi slicks
Body:
Ground up paint work with all rust removed.
Paint colour is Championship DC2R white
ZG Flares from Spirit garage in Japan (not some ebay reproduction)
Polyurethane front spoiller with brake ducts
432z front grill
No dents or dings on the car at all.
Interior:
4point rear roll bar
Recaro carbon fibre Drivers seat
Recaro fibre glass passenger seat
OMP steering wheel
Mild strip down but underbody heat shield to reduce cabin heat.
As you can see this car has been built for the purpose of being a weekend track car. Since it was finished though in 2007 it has seen only 6 track days. Happy to ship interstate. Please enjoy the pics but do not call unless you have available funding for purchase. As you can see this was a moderate budget build and I don't expect to even get half the money back hence realistic with sale price.
Best time to call is after 6pm and weekends.
Selling due to needing rear seats for my little 2.5yr old on those family wkend drives.
Free camping bag thrown in so you can set up tent next to it and enjoy it after purchase :mrgreen:
Price:$38,000
0402136861
Cheers,
Will.
Edited by MKI4EVA
https://www.sau.com.au/forums/topic/425734-syd-fs-1972-240z/
Hi Will,
USA is mad about these.
Have you contacted Iron Block (aka Iron Chef) to research whether or not to advertise the "Z" over there > export it to the US?
Cheers, Tez
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
