The windscreen wipers have suddenly stopped working. The tailgate wiper is OK. Fuse in inside fuse box is OK.
When I turn the ignition on to "Acc" the wiper arms move just a bit with a slight clunk. When I turn the key off, it does the same, and this is with the wiper control arm in the OFF position.
Any clues please.
https://www.sau.com.au/forums/topic/425742-wiper-problem/
Curious problem ! I did some reading and some skyline owners have had faulty ignition switches cause this.
Some said that there is a blue relay down in the drivers side ( near the fuses or possible behind kick panel ) that could cause the issue.
Something is making it get moments of power at on and off. Which could point to a bad ignition switch, indicator switch, relay or wiring issue.
Have you fiddled with anything prior to the issue occurring ?
Edited by Jezboosted
https://www.sau.com.au/forums/topic/425742-wiper-problem/#findComment-6862754
