Hi guys
Trying to understand power and top speeds at various race tracks. I know there are a heap of variables but i'm doing this just to get a general idea.
What would be useful is car, weight, power (kw at the wheels or estimate) and aero. Yes, other things like gearbox (sequential vs H pattern), gearing and traction come into it but, like I said, i'm just after estimates.
Ideally your speed will be via a gps system rather than a quick glimpse at the dash.
I'll start...
Car: 33 GTR
Weight: 1650kg fuelled with driver.
Power: 450awkw (claimed)
Aero: standard
Wakefield: 214kmh
Eastern Creek: 245
Mt Panorama: 272 but backed off very early cause i'm weak.
Add what ever tracks you've raced at.
I'm predicting that my speeds are low for the power level, but we'll see.
Edited by tk80
https://www.sau.com.au/forums/topic/425745-top-speed-circuit-vs-power/
The biggest factor in top speed is power, when comparing similar. Aero differences from different wings, whether you have the windows down, etc will play a small part as well. Grip levels will play a small part also as it determines how early you can get on the gas. Car weight and wheel weight also plays a part, as does tyre width. Skinnier tyres with a higher grip level will out perform wider tyres with lower grip, because wider tyres create more rolling resistance.
Your mid and exit corner speed out of the last corner onto the straight plays a major part in your terminal speed at the end of the straight, I have about 110kW atw in the Speads, but I'll hit 260+ at the end of the main straight at PI due to coming off of the last corner well.
R33 GTST,
350 rwhp,
Home made front splitter & Gt wing
Lakeside 57.6 sec
232 kph into carousel
217 kph into hungry.
F, 245/45/17 FZ201
R, 255/40/17 FZ201
QSTAR/Race chrono.
big speeds Noddy!
obviously got alot more power now than whenever we've been on the track together!
Only about 50hp, most gains have been in aero and suspension. These federals have such woweful grip i have put a lot of time into setup. LOTS OF TIME. As a result, mid corner speed os up 10-15 kph at carousel, hungry and estern loop. So looking forward to the new motor and better tyres.
I have a little ae86 levin out of Japan. Ex TRD cup car, its only got 150 rwhp, 920kg wet with driver, punching out 60.8 sec. Its na1600 on webbers 225/50/15 V70A. Such a fin car to drive. Changing gears @ 8500-9200 rpm...ind bending.
Edited by Noddy
got a video or link to the results Stuart?
Car: 180SX
Weight: 1360kg incl driver
Power: 200rwkw (claimed by previous owner when i bought it)
Aero: none
Box: stock H Pattern
diff : 4.3 shimmed viscous LSD
Tyres: Federal FZ201
Lakeside: 205.5km/h
Time: 59.6 (05/04/2012 on Natsoft and QR's 2012 midweek sprint results)
link to video or results for that too please :)
S15 so not directly comparable.
Car: s15 200sx
Weight: 1150kg without driver
Power: 265rwkw
Aero: wing and front splitter
Wakefield: 199km/h (via data logger but that is with my foot still completely flat to the floor at the kink)
Eastern Creek: 228km/h
1.04.0 at Wakefield
1.39.6 at Eastern creek
Have a new engine in the car now that is yet to go to the track.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
