Carbon Fibre Or Fibre Glass Parts 180Sx,s15,r32,r33,r34,r35,evo
ahah im noob.. read the first post which has prices >_>
Q1, does the rear diffuser come with the side vortex thinggos??
Just put me down for wing blade and exhaust shroud for now though.
Edited by YE34OK
Longz : R34 GTR Nismo Side skirts , Rear pods , Canards, exhaust shroud cooling panel and rear diffuser, EVO side skirts, canards, rear exhaust shroud
haz_jaz : skirts/pods and CF Wing blade for R34 GTR
Terry_GT-R34 : EVO Skirt Add-ons , Radiator Cooling Panel, Rear Boot Spoiler Lip
jase_c : R34 Gtt radiator cooling panel
DeaN20 : R32 GTR radiator cooling panel
Charles89 : R34 GTT CF radiator cooling panel
Sinno: Evo rear diffuser and canards.
Some guy: 350z lip + skirts
joelsy777 : R33 hood bonnet lip.60mm Pillar gauge cover,B Pillar cover, Centre console arm rest
DJRIFT : Carbon mirror cover r34gtt
YE34OK: Carbon wing blade , Diffuser exhaust shroud
gtsttrk:R33 Bee R wing
Coldfusion : R32 headlight intake
tomo : R34 cooling panel, R34 mirror covers
OON80 : R34 GTT canards
Group buy looks good so far ! order should hopefully be put in soon after confirmation with everyone !
for all the people that are thinking of jumping in now is the time !
Missed me off the updated list again.
Thanks for putting up the pic of the mirror covers.
I will have
34 weather sheilds
34 mirror covers
32 lh headlight
Thanks
DJRIFT : Carbon mirror cover r34gtt, R34 weather shields r32 lh headlight < --- updated :action-smiley-069:
Sweet, would I be able to get a pic? I'll add that to my order aswell then.
R34 GTT carbon cooling panel, R34 carbon mirror covers and a R34 GTT carbon boot.
tomo : R34 cooling panel, R34 mirror covers, R34 GTT carbon boot
Did you hear back about the B-pillar covers?
I'm in for an R33 GTR OEM wing blade either way. Let me know about the B-Pillars then I'll decide on them
any pics of this gear? i could be interested in some of the 32 stuff
Thanks
So the pictures posted is not the actual product? Just some found on the web?
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
