Hi All.
Once I get back from my Thailand Trip!! Wooo, ill be making some new upgrades.
I'm looking to get a new brake kit that's not 10 grand like most of them.
http://conceptzperformance.com/Cart/description.php?II=3303&Car_Type=G35&UID=20130524002102219.90.244.239
This akebono seems like a better upgrade from just stock brakes. I know it's no brembos but better than stock.
Anyone know of any other places to get them? Or a different option maybe.
Thanks
https://www.sau.com.au/forums/topic/425801-akebono-big-brake-kit/
Hey mate, I am considering upgrading to a V36 in the not-too-distant future, at which time I will probably pull my slotted floating rotors and Brembos off and sell them. How soon are you looking to do it?
FYI that kit you linked to is great, but once you pay for shipping and GST/duties, you will be WELL the wrong side of $3k. They are not too far off 100kg for all that gear believe it or not. Shipping from the USA is a bitch.
Ahh, have you got any specific photos and specs of your kit? link maybe.
Yeah i have looked at the z1 site, 2500 and 200 delivery that includes berk hfcs and a free cap!!!
I just pmd conceptz for a quote.
See how we go.
Ps. Get back from Thailand 17th June...so that soon
Edited by runner4life
My kit is standard Brembos off a manual V35, with Stoptech 2 piece floating rotors http://www.z1motorsports.com/350_g35/product_info.php?products_id=5563
Nah, let me guarantee you that delivery WON'T be $200. Like I said the kit is about 100kg. I paid about $350 to ship mine here a few years back, and postage rates were much cheaper then vs now.
Also, it is illegal for the US business to not declare the correct value, so you will find that for items of this value most will put the invoice amount on the package. Duties and GST on products worth $2,500 will run you around $400 in duties and GST (assuming $200 postage cost is correct, which it is not). Just factor this into your decision.
I will be asking $2k for my kit, and it will come with decent pads too. I probably won't take off my braided lines, but tbh these made NO difference - I wouldn't bother if I was you. If you DID want to bother, braided lines can be had for around $200 delivered out of the USA.
I'll just wait back to hear from the two companies and see how I go!
I'll keep yours in my mind too!
$495 from Conceptz....so that would be $2335.
Not bad for alot of kit....I will see what the z1 site does it for with the berk HFCs too.
I'm not worried about being illegal. Where I drive, all the cops know me ;) Advantage of being "in house"
Is there a disadvantage to the adapter? Why illegal?
I have aftermarket 18s. The site says fits 18s and above...Hopefully is ok, i can print out a template to check.
Whilst I sorta agree, going overboard with brakes and tyres makes more sense than doing so with power mods.
Also, the "Z1 Akebono Big Brake Master Kit" comes up at $1700 delivered for me - although that is with Infinti calipers, Centric rotors and pads and no brake fluid.
Curious as to where have you seen a full kit of V35 Brembo's for $850? :woot:
I just think its a reasonably priced viable option for safer brakes...and you can go through the hills in comfort. Im going to get mine powder coated yellow/gold. Cross drilled and slotted will look sweet.
I have expensive tyres, so makes sense to get better brakes if they can handle it.
Well this will be closer to 2.5K by the time it gets here
Locky if you read what iamhe77 has actually written, for the brake set alone from Z1 it is free shipping. Confirmed by Z1 themselves. So where is the magical $800 extra coming from?
I've done some reading on cross drilled. I'm not going to be driving track, I do that in the cop cars enough. So crossed drilled is "ok" unless your using them in severe applications, street driving....severe? no, unless you want to be stopped by me and have a chat with a friendly officer ;)
Worst case scenario I change rotors if they happen to crack after however many ks? meh
They won't crack.
I ran cross drilled 296mm on a full weight m35 on a light track day. No cracks.
Running really high 800+ degree pads on a race car doing lap after lap? Sure, they will crack. Considering Porsche and orher high performance marques, use cross factory discs, I'm not sure cross drilling has a lot to do with it, rather disc material composition.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
