LOL, one is 4WD and the other is 2 wheel drive.. There is 3 gauges in the centre dash with boost pressure, torque split between the front and rear diffs, and oil ??
Flared gaurds on the GTR, same wheel dimensions front and rear,
Just look up some pics on google to have a look at them also..
Ask them!
Check the engine ..
Hehe I wasnt specific enough LOL
This cars interior and exterior is HUGELY different to a standard Skyline, Engine bay is also quite different. I was thinking more around the Model no. BNCR33 printed on the engine or something like that? Maybe even what to look for in terms of the 4wd system/front diff....
I'm not a noob.... REALLY!!!!
Bepo
im asssuming ur talkin about the r33?
i no how to tell easily if a r33/r34 is a real or a fake gtr but i have to admit i realli cant tell the difference betweeen a gtst and a gtr for an r32!
i can sometimes..but sometimes i get it confused
it loooks pretty similar to me
just looking at the car flared guards is easiest for me... assuming that extreme mods doesn't include pumping the guards out
GTR -
pumpness... not to mention a GTR badge :)
GTSt -
flat... like wall
thankyou to whoever's cars i used.
Meshy.... Yes it is he one from Ebay although i saw it advertised elsewhere, dont really likethe color but the modded panels and bodykit look sweet. Any info on this car would be great as the owner has conflicting stories about the car.....
I'm becoming less and less interested in it though as it isnt really the image I am after LOL
Bepo
man i've seen the car and its a real GTR. he was getting his kit done when i was getting my kit done. plates GTR-007 right? was also at MAS. what conflicting stories has he got with the car?
Yeah thats the car alright. As for conflicting stories, it is more a few vague facts like he said the kit was on it in Japan and your saying it was done here hehe, it has also changed hands twice in a year which doesn't bode well. Anyways I dont really want to air this on the boards, I am more interested in anyone having knowledge surrounding the cars, mechanics and more importantly if it has accident history. Any respray raises my suspicions
Bepo
Had too put this in :D
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
