Never heard of horror stories with this, so long as its used for its proper purpose.
Not for AFM filament I don't think.
It's so powerfully effective, it's been known to take grime off wheels that nothing else could remove.
It was always used at every service on my Subie Foz XT down the piping. Recommend!
If you read the directions on the can, it stipulates to spray half of the contents into the inlet manifold while the motor is off and to wait 10-15mins before starting so it can do it's thing. Then, when it eventually starts, it will take some cranking to get it going, speed the motor up to 2000-2500rpm and spray the rest of the contents on and off letting the motor breath. The revs will drop as the nozzle on the can is depressed.
Any Success/Horror stories?
Lawwwwllz. Yes.
I was spraying the straw into one of the ports on the plenum and the vacuum sucked the straw right off and right into the runners.
After trying madly to get it out with a grabber tool, I only ended pushing it further in.
I eventually gave up and ran it through the engine.
That was a few years back and I never think it did any damage.
Moral of the story: attach some thin pvc tube or similar to the nozzle. That way you can always keep the can upright, and the straw wont get sucked through the tube.
Good shart, but beware, if you leave it for too lone it will start to eat gaskets and goos. Also, don't use on rb26's per throttle body as it eats the thin film of silicon that seals the butterflies. You have been warned.
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
