Before anyone says, yes I have searched and on many different forums
My rb20det was running fine one day, then started to develop a very bad miss on boost, so changed to NGK0.8gap copper plugs, new wasted champion spark leads, and the missfire continued.
A few weeks later after not driving the car, it was very hard to start, then when it finally did it sounded like it was running on 3cylinders, would idle but struggle insanely to rev past 3k rpm without sounding like a bee r limiter
I have changed the standard ecu, maf, injectors, plugs, leads, cas, a bunch of grounds, no error codes etc etc
It runs super rich backfiring if i manage to rev it past 3k rpm, but yet each cylinder has good spark and makes no difference when anythings swapped around
Oh and for some strange reason when the car has warmed up it runs better (running very bad still) to the point i can drive up and down the driveway, but it splutters and full boosts and wont get past 2500rp
Anyone have any ideas they could throw out? the car is completely standard except a straight pipe exhaust, pod
https://www.sau.com.au/forums/topic/425838-rb20det-very-strange-misfiring/
I'm having the same issues at the moment, although mine doesn't seem as bad. My misfires around 3 - 5k rpm, still goes hard, but yeah is still misfiring. I've tried cleaning AFM with carby cleaner, changed spark plugs, changed fuel filter and my coilpacks are only 500kms old and they are splitfires. Going to try and put in new coilpacks and see how i go, :x. But yeah good luck with yours, if i find a solution and it's not one you've tried yet i'll let you know.
Yep please if you do find out let me know, Ive heard of the looms being the problems aswell but ive checked mine and it looks fine but maybe might be worth me changing it
And to the above posts, I have a wasted spark setup.... similar to http://www.skylinesaustralia.com/forums/topic/115690-wasted-spark-ingnition/\
so uses leads to go from the packs to the spark plugs, but this has been tested and is working fine also....
Sounds like coils dude. When they crap out it is under boost. when you say tested already what do you mean? just seeing if they spark? That's not enough to confirm they are working under boost/ higher revs. You need to swap them out with known good ones.
Edited by superben
Actually something else to consider is the dwell the coils require.
If you arent supplying the correct dwell, the coil wont be operating at its optimum, meaning when it craps out just a little it really craps out, if that makes sense,
I did an LS2 coil conversion, and with stock dwell it would misfire on boost (18psi) with brand new coils. Once dwell was adjusted with Nistune, miss went away.
Im not missfiring on boost, im missfiring constantly off and on boost at all rpm, its not a small missfire, this is huge, stopping it to even rev past 3k rpm,
its not running on all cylinders, cant even rev properly. The packs voltage it was sending out was test and found to be ok, ive also tried other coilpacks that are known to be working fine and it runs the same on this engine.... so i dont think its coilpacks
Edited by R33 0wnerrr
Just because a coil packs output voltage is ok under no load, doesn't mean it's firing properly under load.
What coil packs are you using? What part no plugs?
Have you considered it might be the igniter or CAS?
Is your fuel pump working ok? A dud fuel pump and or restricted fuel system will cause an engine to not run on all cylinders.
Ive swapped my setup and used a friends spitfires and they had the same problem in my 20det, same with his cas, and igniter. Have used BCPR7ES 0.8 and a set of iridiums
Fuel pump seems to be working ok, i presumed seeming it has been running rich backfiring extremely when rev'd up that its working fine, the injectors are all working and have been swapped also, but might try swap the fuel pump and see what happens?
Ok good idea especially as I have a fpr lying around somewhere in the garage that i can hookup
Yep maf has been changed 3 times with working ones and when its unplugged it will stall. Ive checked all my pipes for leaks etc cant see anything
im experiencing a misfire on full boost on my rb20, its running a gt3076r .82 rear housing mapped on a power fc, after about 5500rpm it misfires and hesitates.
also the cat temp light flicks on and off which im told is a pfc check light.
car was mapped and is boosting 1.3bar
I swapped plugs for bkr6evx11 iridiums.
what should I swap out next, coils loom and ignitor?
car runs fine apart from that, no miss on idle or out of boost.
in perth If anyone can help
Edited by al-himself
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
