Hey guys I have my hyper ss for sale
This a top notch buggy and very strong.
I did the brushless conversion using quality parts
Esc: turnigy 100 amp track star esc
Motor: turnigy track star 2350 kvetching motor
Servo: savox titanium geared servo
Shocks: hyper 9 shocks
Everything is in perfect working order.
Also comes with a turnigy radio
And 4x 4c 5000mah batteries and 1x 5c 5000mah battery.
Iv strapped my fone to the buggy with a gps speedo n was reaching 86kms with the 5c....
Currently has a broken arm n wing, but will be replacing them
Pick up is from officer 3809 or postage is guna b expensive.
0437581414
https://www.sau.com.au/forums/topic/425857-hyper-ss-buggy/
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
