I have made this thread to hopefully educate not only myself, but to educate all skyline enthusiasts in general.
What i'm hoping to do is create a list of parts that are interchangeable between the different models of skylines, whether they be coupe/sedan or turbo/na and start a general discussion on what some of the available options are for us (if any at all).
I know that s13/s14/s15 have an outstanding list of interchangeable modifications between the three different models and I am somewhat trusting there is some compatibility between models for our skylines.
I realize this may have already been done on another thread and if so someone please link me to the specific thread.
I myself have started this topic because i have a naturally aspirated 1999 R34 GT-V Sedan and was wondering what coil overs i should use, or if possible just drop in aftermarket coil overs from say from an earlier model skyline?
I also have a few queries on the exhaust system on how they differ from each model and if they differ from coupe to sedan?
Anyhow, any information on any parts that are interchangeable regarding skylines please discuss below!
i guess starting with the suspension wouldn't hurt though haha! :whistling:
Any information provided will be extremely helpful not only to me but im sure lots of others too.
Thanks in advance :rolleyes:
Cabin rear view mirror. 34 fits 32 and I'd suggest 33 and a number of other Nissan models. Eg S13 etc...
Looks like the map lights and cabin light are the same for 32,33,34 models.
Recently posted was the underside of the 32, 33 and 34 showing the exhaust systems perfectly highlighted. Will try and find if your interested but needless to say not interchangeable.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
