Completed fitting the tomei sump baffle today. To my surprise, the holes that needed to be drilled according to the instructions were already there!
So I got my money back from Bunnings for the 400mm long drill bit that I bought just for this!
Also cleaned the intercooler today...should have the clutch on tomorrow as well given that my friend can drop off the input shaft for me.
Weather is looking pretty crap for the end of the week so might not be able to get the engine in before the end of the week as the car sits outside :(
Updates and photos are becoming few and far between but progress has been good.
As per last post, the intercooler has been cleaned and plenty of coolant and oil came out of it with now only clear water running out which is a good sign.
Which also means everything that was connected to it suffered the same fate.
bovs after a clean
Religiously cleaned ready to be put back on
Genuine Nissan left, Ryco right
971353_10151582202443031_1751186265_n.jp3
And the engine is now all bolted in, most of the loom all plugged up (correctly I hope), starter motor in, all that's left is the minor stuff. Let's hope for no more hiccups and a smooth sail start up by tomorrow night! Fingers crossed!
Unfortunately there was a bit of a problem...
Filled the thing up with fluids and water in the radiator. Noticed a leak and turned out to be turbo water lines
There's no way of me getting it tight enough on the engine so theyre coming back out to check all the banjos
are tight as a nun's you know what.
this is the very reason why I chose to replace the oem water and oil lines with braided lines.
ANDDDD turbos back on! So the banjos were hand tight only, must've slipped my mind to tighten them after installing onto the engine. Nothing is leaking now and tomorrow will be the start up day if nothing else happens touchwood!
So got the roadworthy no worries and just been doing little bits and pieces here and there now before I can chuck all the other stuff on after VicRoads tomorrow :D
My friend came over and took some better quality shots of my car for me so here they are!
1074457_10201203791150010_832162693_o.jp
1077878_10201203790229987_1841301106_o.j
202652_10201203784509844_1390677156_o.jp
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
