hey all. I went down to nizzpro today and got myself a diagnosis port from an old sr20 180 to put into my rb20.
The question I have is, am I able to connect the diagnoses plug cables to the wires coming from the correct pins on the ecu, or do I have to solder it directly onto the ecu pins?
It just seems it would be a much easier job if I can connect to the pre existing wires by simply splicing into them, rather than having to try and solder onto the tiny pins in the ecu. Plus it means that there is no chance of me connecting to the wrong pin as they are all close together, dropping solder into the ecu, or accidentally soldering two pins together by a random string of wire or piece of thick solder. that would be very hazardous to the ecu.
any input would be greatly appreciated
Kind Regards,
Poeticjustice88
https://www.sau.com.au/forums/topic/426013-diagnosis-port/
if i was to solder to the wires, would I have to cut the existing wires to stop excess noise or interference.
what I mean is. for example, if I need to join to the wires coming from pin #1, 2, 3, 4 and 5, do i join my diagnosis plug to the wires coming from the ecu and then cut the rest of the original wire off? Or do I splice into those wires and leave the originals connected to whatever they are?
Kind Regards,
Michael
https://www.sau.com.au/forums/topic/426013-diagnosis-port/#findComment-6872461
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
