Hey all,
Ive been looking around like crazy but having no luck finding a hose from the power steering pump.
Now from my reservoir there are two a small one and the thicker one.
The small ones you can get replaced from autobarn/repco and them however the big one I cant find anywhere.
Nissan dealerships cant help out either so im guessing it has to be sourced from Jap or go to a hose manufacturer or something.
Anybody had theirs replaced??
Pic attached is the hose i was talking about taken from "Part Number" thread.
Thanks in advance
https://www.sau.com.au/forums/topic/426014-98-gtt-power-steering-hose/
ah cheers for the replies.
Kudos probably wont have it but ill give it a shot.
amayama.com under "49719: tube assembly, power steering" have it listed for $168USD + delivery, but no pictures so I cant be 100%
I will drop by enzed and have a look for a matching part - when I have confirmed it and replaced it ill post the results. All else fails ill order through amayama.
Edited by milanr34
They won't have a matching part - they will make up a suitable hose.
  • Like 1
Yea Kiwi,
I didnt have a chance to do it this weekend because of all the rain, but this Saturday coming up I will ask them to make the hose and give me the specifics. Upon the results I will post them here so others can know exactly what to get.
Well I gave them a call and they said they dont have those parts......anywhoo what i did do is a total flush and cleaned the hose thorough and put it back in.
After testing for leaks there wasn't any so ill leave it sitting for a bit and see what happens - could be that the previous owner didnt put the clamp on properly.
Either way ill report once its back in.
Out of curiosity which NIssan place did you call?
im from SA, I had part numbers which I found on the forums
went to my local Nissan dealership (lakeside Nissan) paid a deposit, they ordered the parts in. from melb I reckon
had them in a few days
reckon I paid about $150 odd for both hoses. bit pricey for hoses
Update:
Turns out my hose wasn't split it was damp due to the top clip not being on properly. So as such there was no need to replace it.
However would be good if anybody can advise the part number of that hose as I see some SAU members need it as well. Ill keep on searching and post the results if I find anything.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
