Hey all,
Ive been looking around like crazy but having no luck finding a hose from the power steering pump.
Now from my reservoir there are two a small one and the thicker one.
The small ones you can get replaced from autobarn/repco and them however the big one I cant find anywhere.
Nissan dealerships cant help out either so im guessing it has to be sourced from Jap or go to a hose manufacturer or something.
Anybody had theirs replaced??
Pic attached is the hose i was talking about taken from "Part Number" thread.
Thanks in advance
https://www.sau.com.au/forums/topic/426014-98-gtt-power-steering-hose/
ah cheers for the replies.
Kudos probably wont have it but ill give it a shot.
amayama.com under "49719: tube assembly, power steering" have it listed for $168USD + delivery, but no pictures so I cant be 100%
I will drop by enzed and have a look for a matching part - when I have confirmed it and replaced it ill post the results. All else fails ill order through amayama.
Edited by milanr34
They won't have a matching part - they will make up a suitable hose.
  • Like 1
Yea Kiwi,
I didnt have a chance to do it this weekend because of all the rain, but this Saturday coming up I will ask them to make the hose and give me the specifics. Upon the results I will post them here so others can know exactly what to get.
Well I gave them a call and they said they dont have those parts......anywhoo what i did do is a total flush and cleaned the hose thorough and put it back in.
After testing for leaks there wasn't any so ill leave it sitting for a bit and see what happens - could be that the previous owner didnt put the clamp on properly.
Either way ill report once its back in.
Out of curiosity which NIssan place did you call?
im from SA, I had part numbers which I found on the forums
went to my local Nissan dealership (lakeside Nissan) paid a deposit, they ordered the parts in. from melb I reckon
had them in a few days
reckon I paid about $150 odd for both hoses. bit pricey for hoses
Update:
Turns out my hose wasn't split it was damp due to the top clip not being on properly. So as such there was no need to replace it.
However would be good if anybody can advise the part number of that hose as I see some SAU members need it as well. Ill keep on searching and post the results if I find anything.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
