Hey all,
Ive been looking around like crazy but having no luck finding a hose from the power steering pump.
Now from my reservoir there are two a small one and the thicker one.
The small ones you can get replaced from autobarn/repco and them however the big one I cant find anywhere.
Nissan dealerships cant help out either so im guessing it has to be sourced from Jap or go to a hose manufacturer or something.
Anybody had theirs replaced??
Pic attached is the hose i was talking about taken from "Part Number" thread.
Thanks in advance
https://www.sau.com.au/forums/topic/426014-98-gtt-power-steering-hose/
ah cheers for the replies.
Kudos probably wont have it but ill give it a shot.
amayama.com under "49719: tube assembly, power steering" have it listed for $168USD + delivery, but no pictures so I cant be 100%
I will drop by enzed and have a look for a matching part - when I have confirmed it and replaced it ill post the results. All else fails ill order through amayama.
Edited by milanr34
They won't have a matching part - they will make up a suitable hose.
  • Like 1
Yea Kiwi,
I didnt have a chance to do it this weekend because of all the rain, but this Saturday coming up I will ask them to make the hose and give me the specifics. Upon the results I will post them here so others can know exactly what to get.
Well I gave them a call and they said they dont have those parts......anywhoo what i did do is a total flush and cleaned the hose thorough and put it back in.
After testing for leaks there wasn't any so ill leave it sitting for a bit and see what happens - could be that the previous owner didnt put the clamp on properly.
Either way ill report once its back in.
Out of curiosity which NIssan place did you call?
im from SA, I had part numbers which I found on the forums
went to my local Nissan dealership (lakeside Nissan) paid a deposit, they ordered the parts in. from melb I reckon
had them in a few days
reckon I paid about $150 odd for both hoses. bit pricey for hoses
Update:
Turns out my hose wasn't split it was damp due to the top clip not being on properly. So as such there was no need to replace it.
However would be good if anybody can advise the part number of that hose as I see some SAU members need it as well. Ill keep on searching and post the results if I find anything.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
