I took my R34 Gtt in to get tuned on monday, the usual stage one mods, (Front mount, 3" exhaust with dump, pod filter, cold air box, apexi avc-r and flowed turbo plus water/Methanol injection and a Greddy Emanage ultimate controlling it) and when my tuner hooked the car up to the laptop the emanage needed an update on the software. As soon as that was done the car shat itself basically and the update either corrupted the emanage or the tune i had in there already. The car would run but wouldnt idle at all and was belching unburnt fuel. I had to bypass the emanage and run off the stock computer to get the car home and now that my maps are corrupted or changed they are basically useless.
I was wondering if anyone out there may have an emanage in their auto Gtt and may be able to help me out by sending me a copy of their map files so i have a reasonable base map to start from again so i am not paying shitloads of dyno time to get my car running well again as i am already down one full days tuning $$ and took a massive step backwards.
Really hope someone can help me out.
https://www.sau.com.au/forums/topic/426032-greddy-emanage-ultimate-maps/
If you update the software you need to update the Emanage Ultimate or it won't work. The map should be fine if you still have a copy...
The software on the emanage ultimate was updated thsts what stuffed everything.
If you have stock injectors etc.. you don't need a map for it to idle. Is your AFM the normal type for the motor ? And yes you need to do 2 updates one for the software and one for unit.
Please note if you have a laptop with windows 8 good luck... In order for it to work you need non usb 3.0 and since Microsoft only have the drivers for windows 8 it stops them working all together. I found with windows 7 u need a virtual machine running xp with 2.0 drivers ( you can just uninstall the 3.0 drivers and it reverts back to 2.0 )
Sounds like you need to plug your laptop in and connect to your Emanage and check to see if the basics are setup ( engine type..AFM type, CAS angle sensor, ) re do those also are the toggle switches that turn your maps on on the unit turned on? ( the little yellow ones on the side of the unit ) ill send u a pm with my mob no as it easier to talk than to type. Cheers
Edited by Kenna802
Everything was running fine(and the basics are still setup ) and had been setup since i got the car but after the update it wont run properly and it wouldnt let us in to save the maps before it updated so i have nothing to fall back on or to compare the maps to now so i can pinpoint whether the unit itself is the problem or if it changed the maps or how it is reading them (if that makes sense)
re updated to 2.20 on both the laptop and the emanage unit and no difference, runs rough and when you blip the throttle it dies, disconnect the emanage and go back to the stock ecu and it runs fine. WTF???
i updated mine to 2.30.
and it shat itself the next day. it would idle fine and drive. but when i put my foot down more than half way it would sputter and not rev, so i did the same at the moment, went back to stock for now.
I'll figure it out when i get my car back from my mechanic.
I have a feeling that the update changed something slightly and the car didnt like it. yea i know, thats not a big help and a very big guess. but its all i have.
i'll let you know what i find out.
yep yours sounds pretty much what mines doing Canada, sort of what i was thinking, that it changed something or maybe the update corrupted something in the units? i changed the maps back to default (all values 0.0) and still the same.
Yeh im back at 2.20 and it hasn't helped, might try taking each factory sensor off the emanage seperately and running it off the stock ecu to see if that will pinpoint where the problem is in the emanage.
So i did a data log on the Emanage today and can see where the problem is, just not whats causing it. When i give the throttle a little blip (around 15%) the output injector duty is hitting 100% and the rpm is only 1300 or so. even when idling the input and output values are a bit different even though the values on the map table are 0.0
Anyone else had problems after the software update that totally screwed the unit?
Edited by jase_c
i'll post the links to my data log and what my car was doing. i think i need to start from scratch. set everything back up as if it was the first time.
I had enough issues with v220 and getting my car to run. one thing that i had with my setup was the car wouldnt run right with the settings at stock value for injectors so i have to play with the injector settings up until it would run normal.
what are stock injectors? 370 or something. i think i had to set mine at either 440 or 550 or something. i think it was whatever the gtr stock injectors were.
anyway i will go through it all whenever i get my car back. i was really interested in this update. was liking the fact that autotune was going to work properly on it own. :)
(watch in 720p so you can read it)
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
