hey ladies and gents, been scouring SAU trying to find a solution to what has now been dubbed the "crapper's" misfiring issue, so I thought id introduce myself while im here.
names Matty, live pretty much in the middle of newi/central coast. picked up an R32 gtst a few months ago, fair few mods ongoing work in progress. When it actually works ill look forward to joining in a few cruises and such.
and there it is.
https://www.sau.com.au/forums/topic/426038-mattys-32gtst/
and there it is.
Hey mate, contact DVS JEZ if you get stuck and need someone to look at it for you!
Also, there is a cruise on the 16th if you are sorted out and keen! Its more a meet and greet type thing so bring your beast out and show it off!
https://www.sau.com.au/forums/topic/426038-mattys-32gtst/#findComment-6870129
Yeah Jez did my tune few months back, good bloke, car came out great. Until now. Can't really do much over the top cash being tight these days
:/ it'll get there hopefully it's running mint by the cruise so I can tag along
Yeah see if you can sort it out! There is the Newcastle Skylines FB page that you might be able to borrow parts from? Or ask on here.... I dont have access to anything from 32's so i cant really help...
https://www.sau.com.au/forums/topic/426038-mattys-32gtst/#findComment-6870150
You got more detail on the missfire? Its not likely to be the coils if you have just fit them! On that note WHY did you originally fit them and is this the same issue?
https://www.sau.com.au/forums/topic/426038-mattys-32gtst/#findComment-6870161
Stock coils wouldn't hold up past 4.5k during the tune so Jez dropped in a set of his splitfires to do it. Bought a set put them in, ran sweet for a couple weeks.
It's popping on boost at 4k+ sometimes misses just as it comes on
Sometimes on startup it runs on 5cyl struggles to rev and spool Put the boot down as it coughs to limiter and it clears up. Only does it about 10mibs after running temp. Plugs are less than 40km old bcpr7es-same as what Jez used. I'm assuming its fuel or ignition
https://www.sau.com.au/forums/topic/426038-mattys-32gtst/#findComment-6870176
Hahaha :/
I make a measly 191rkw or 206@18psi
But it still skids :)
Mine only makes 200 more :P BUT its taken me 5 years to get it there lol...... Things happen slowly and cost fkn HEAPS!
Not bad power for a light car in your case ;)
https://www.sau.com.au/forums/topic/426038-mattys-32gtst/#findComment-6870264
