hey guys I have some stuff left over from the silver r33 coupe I recently parted out, parts left include:
not much left now only have:
stock air box - $180
boot interior - $70
clutch pedal/master/lines/slave - $150
abs bmc - $50
booster $50
rear seats - $20
front and rear door cards - $100
f & r pillar trims - $20 each
dash - $50
glovebox - $30
s1 centre console - $30
bonnet - $100
boot lid with wing - $100
front bar (m spec s1) - $100
rear reo bar - $50
bonnet latch and stand - $50
washer bottle - $20
coolant bottle -$20
pass window switch - $30
engine crossmember -$50
hicas steering rack - pending payment
rear suspension arms - from $20
mirrors - $60
good flywheel - $100
fuel filler flap - $25
fuel pump and cradle - $50
probably more little bits around but thats most of what I have left...
located in springwood 4127
please contact me on 0420 767 957
Cheers
also got a series 1 shell here now to part out (complete coupe shell)
still got heaps of s2 parts as well and lots of r32 stuff
rb25det block complete unknown condition bores look very good - $100
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
