Very interesting build mate. Can say I have seen this car around before! Tough car keep the log going :)
Again. Thanks for the good words. I appricated positive feedback.. even though it isnt a Skyline or even a nissan! Where have you seen it around?
Having real problems now..
I keep looking at Widebody kits... O_O
ARGH! What to do...... FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU~!
Edited by Tonba
Cool build Tonba. I've grown a real soft spot for evo's lately. Did the stockish setup of the 8 get boring too quickly or were you just modifying it without any real plan to begin with? I only ask because I'd like to own an viii myself one day when I sell the sky.
Thanks copycutter.
I originally set-out to build a car to do street duties, run consistant 12's at the strip, and 1:08's at Wakefield.
(Remember this was 5-6yrs ago, when 98RON was the norm and a 1:06 @ wakefield was consided SUPER quick..)
I managed to get 220kW, low 13's (13.1-13.2 sec passes) and a high 1:08 @ wakefield., but the engine developed a problem with the lifters and oil-rings so we decided to rebuild. From there things just snowballed. I kinda lost my way with no real plan, and ended up with a car that simply was not fun to drive on street - Im sure #@34GeeTeeTee can help me elaborate there...
After just too many engine/tune issues, and now hating on the car, I took the car to JEM and they found major issues with the engine build.. So the decision was made to 'start from scratch'. Every item I am picking is to build an absolute street monster..
The NEW goals are;
-Street Car, Understated but turns heads
-Run in the 10's in the quarter mile in FULL STREET TRIM (ie street rubber, synchro gearbox and all)
-Run a 1.04 to 1.05sec lap at wakefield.
Edited by Tonba
If it didn't have issues when it was at 220kw do you think you'd have still gone full house eventually? Is that a common fault with evo 8's or were you just unlucky?
If you knew this clown you would know the answer! He is halfway through one build and already planning the next :P
Look, 220kW was very fun on the street, and with e85 it only would have been better. I never ment to go FULL-RACE spec. I just got carried away. But I was always going to build a serious street car.
It isnt a common problem. Just very unlucky.
Guilty as Charged...... :P
Already trying to talk myself out of a Wide-Body Kit & Twinscroll HTA3586R.
Edited by Tonba
My 250kw nugget kept up with you so you wanted MOAR :P That is the true story haha
Just shuddup and stay on target!
You speak the truth. If it wasnt for you mate, who knows what the hell I'd be doing... the car that NEVER runs because its just constantly getting modded. lolz
Hence why you will get the build and paint done and get it back on the street to enjoy! Now get more engine part pics etc online! Carnage and all!
No worries champ. When I get more pictures (particularly of the head) I'll post. At the moment I have nothing new to show.
Lol you two are classic egging each other on.
Why do you think he went to a HTA turbo? ;)
He#@34GeeTeeTee forsaw the need for more power... Scared I tells ya!
Edited by Tonba
Haha Good mates for many years.... Always a good way to get shit done! :P
I have pictures of Carnage! Dont make me post them!
Car head's over to bodyform today. Currently looking into a Varis carbon fibre roof... Depends on timing really. If I can get the roof in 4-5 weeks I might do it.
I think I have decided on colours, but going to paint a test first to make sure while the body is being prepped.
I WAS going to look a widebody, but it now looks like I wont be. Too difficult, and will loose the very 'stock' understated look I'm going for.
Engine wise, not a whole lot is going on. Rods & crank delivered, pistons still being made which will be finished in a week or two. The head has finished getting portwork done, and is currently getting assembled with the valve train. Still waiting on photos. Either way, Ill get photos and post them up when it is delivered which should be before month end.
With the old engine setup, we ran a standard sump with tomei baffle plates, but with the new setup we are considering a Moroso/AMS fabricated sump which has extra baffles to make sure oil stays where is should, and an extra 1.4L of capacity. To go with this, we are also considering a Moroso/AMS accusump, which has another 1.4L of capacity. If and when oil pressure drops during extreme cornering or acceleration, the accusump automatically pumps extra pressure into the system to make sure everything is well lubricated. The additional benifit with all this extra oil, in addition to the twin oil coolers, there should be NO TROUBLE in keeping oil temp's in check.
Edited by Tonba
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
