Hi Guys,
Due to the recent discussions in other threads in relation to the latest HTA results, Lithium and I decided it was time to create a new discussion thread as i do believe these will be a big part amongst the SAU community based on the results possible on the RB engine.
Forced Performance are normally associated with EVOs and STi's which results in them often being overlooked as an option for the general turbocharged world but they actually do a bunch of Garrett based upgrades for a variety of applications (not all are listed here):
And
A lot of these turbos have been around for years, and proven time and again to perform - it is a bit of a shame they aren't more known about in our area in the world. The HTA range came out in the late 2000s (before the Garrett GTX range) and as a general rule provided compressor wheels which made the equivalent GT units completely redundant, typically having physically smaller inducer dimensions (smaller trims tend to mean better response, and safer margain before surge) and the ability through design to flow over 10% better than the GT equivalent, without carrying the extra 25-30% mass the cast GT wheels have... so also great improvements to transient response.
Over the years they've been used on a variety of serious cars in single and twin form, and often FP/HTA technology don't get the credit for it as they will be referred to in articles or the workshops who have supplied kits using them as "custom Garrett" units - key examples for these are Porsche and R35 GTRs, where FP turbos are one of (if not THE) turbo to use on those cars.
They also supply an upgrade service which I am sure means they can built a custom version not listed on their site - which would mean there are the options of a HTA3071R, HTA3073R, HTA3076R, HTA3582R, HTA3586R, HTA3786R, HTA3794R, all the way up to the HTA4505 - so if anything there are actually more sensibly spaced options than currently available from Garrett themselves, and without the design compromises Garrett had to do in order to make them suit the OEM market - such as forfeiting compressor efficiency to be quiet, packaging reasons, and optimising low pressure ratios. This isn't to say the HTA turbos aren't only good at high pressure ratios, they are just more focussed on performance from 1.5-4 bar instead of .8-3 bar - generally speaking. End effect is they suit most of our purposes very well :)
Boost Logic R35 GTR - 8.9 @ 180mph on its first outing, still on low profile radial tyres (AMS downsized brakes and rims): http://www.gtrlife.com/forums/topic/85461-boost-logic-89s-180mph/
And vid:
AWD Motorsport radial tyred/stock ECU EVO - 9.0 @ 160mph (it hit high 8s but the video is cr@p):
Eddie Bello's Texas Invitational winning Porsche from 2013 -
And plenty of time attack, circuit and rally cars have used them to great effect as well.
After researching this turbo in great detail it was decided the HTA3076 would best suit my car as the GT3037-56T compressor was maxed out. Initially i was skeptical about the turbo as it is hard to get your mind around a setup with similar dimensions being capabale of so much more, after numerous discussions the decision was made to test one out and the results were nothing short of amazing! The turbo not on provided more peak power and torque, but the response was dramatically different, on paper it looks impressive but once in the drivers seat, its a totally different beast! I will have all the results on both fuels (E70 and pump 98) and also varying boost levels to post shortly but for now i have a direct back to back full power comparison from a GT3076 vs a HTA3076 -
217352_275271485949967_794567082_n_zps79
And the video provided by JEM of the dyno runs -
The HTA is certainly an impressive turbo and i think with the options of a HTA3073 & HTA3076 for RB25 they have nailed it! The old GT compressor had no answer for the newer HTA design.
I must say a big thanks to LITHIUM as without his help and data i would not have made the choice to choose the HTA turbo, and again another big thanks to Just Engine Management for the awesome tune! Adam Neish knows how to get the best out of any given setup :yes:
Discuss ;)
https://www.sau.com.au/forums/topic/426059-forced-performance-hta-turbos/
Discuss? I think we've done PLENTY of that :) Time to enjoy it.... and I'd like to place a booking for shotgun when I am over for WTAC in October :P
It's certainly a nice change from the GTX3076R which adds the power, but more lag - instead of less :spank: Bewilders me that the HTA3076 has been around so long and Garrett could bring out something that doesn't perform as well and have it look like it could become the new black.
Great write up.
More information for when i decide to upgrade my turbo in the future :D
Certainly keep these in mind if you want good overall power and response! YES you will pay more than other options but in my case the cost is justified!
Nice result. Be interesting to see if you can get it to hold 28psi through the top end. Any thoughts on why it doesnt hold the extra boost in the top end?
Hi Roy,
It was not meant to hold that pressure through the top end! Standard Headgasket and studs etc! That and i do believe the turbo is reaching its ceiling!
What was your initial impression of the HTA wheel you tried?
It is already a pretty intense result for a smallish trim 76mm compressor attached to a GT30 hotside, to hold 28psi up top efficiently the way it is making power you would have be shooting for around 430 rwkw! I think if you were aiming for that power then I think it really would be time to start considering something GT35 based and a built motor :-)
Which is the reason the HTA3076 was chosen as its pushing the limits of the factory internals!
I really wanted to try a HTA3582R or HTA3586R on my GTR but about the only thing that stopped me was the lack of T4 divided housings to suit my manifold.
Trying to convince a few guys in Perth to try out some HTA options at the moment. Fingers crossed we can see some more results
  • Like 1
Yeah that has been a bit of a negative for Garrett based turbochargers for a while, however Garrett do proper T4 twin scroll exhaust housings for GT35 wheels now - so it should be quite doable :) A friend of mine has an HTA3586 with the ATP T4 housing in his new GTR and that is going to be a bit of a monster, too. Should be hitting the rollers soon with a new upgraded fuel system and E85 - I expect it will be fairly silly! Should be able to report results soon.
The same engine/turbo setup was previously in an R32 GTSt and not E85 but met a sticky end:
Awesome! Well keep the thread updated as i can see some good things coming from these turbos!
Sky30 might be able to give us some feedback on his HTA. :)
shit man, im having a really hard time with my undecisiveness so far i had three in mind but after reading here thats another to the list. If only i had money to test the all out. Great write up though man i have a lot of thinking to do.
It really depends on what you want to do but if a recall correctly you wanted 400kw+? If so go the HTA3582.... Otherwise copy my setup and enjoy!
Nice of you guys to FINALLY join the HTA bandwagon!
Shuddup you! Get your HTA powered pig going so we can see where the Black maxes out!
I have done a swap from garrett gt3582 to FP hta3586 with no other mods or changes.
Two main things ive noticed are the fp turbo spools slightly faster/earlier and the fp turbo holds boost better when running 20+ psi.
The gt3582 would not hold more than 21psi on my engine
Great write up and even better that you have results of your own to share. They are impressive.
Like above i looked into these but was limited bu the optioms. I'm on my phone otherwise would search myself but do they now come with the T4 divided options? Something for around 450rwk?
Not sure, on their site it says "other options" but no listing available! The power target will be reached easily enough and still be responsive i reckon ;)
That is awesome! I've noticed a BIG change in the way mine drives, its lively right through the rev range but i havent had too much seat time yet! Cant wait to get back in it and try high boost!
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
