Because going straight to a 94HTA might be too much of a jump in one shot? ;)
LOL no no, because of a reason he can't recall :P
Why not super 99? Because of reason cannot recall.
I find it interesting that FP no longer offer twin scroll housings........
E85 and other variants have probably reduced the dependency on twin scroll systems somewhat. This and twin scroll setups are still likely to cap peak outputs....which is no good from a marketing point of view.
Still prefer a twin scroll setup myself on a street car - coupled with E85.
Yeah, me too. My RB based dream build is pretty much an R33 GTR with an RB30/26 and a TS 3794HTA on the side of it - the concept seems like good thing I get probably a little too happy just thinking about it hahaha
Lol you clowns haha
You get that, because of a reason I can't recall ;)
LOL that's the spirit.
P.S. I would say we dream about the same things, but if you were dreaming about my wife I would be worried. So for now it will have to be just our R33 dreams, for reason I can't recall.
I cant recall how this all started..... But git farked :P
Quick question - does anyone know whether the HTA turbos use the Garrett cores with the metal bearing cages which I understand are used in the GTX turbo's or the plastic bearing cages as typically found in the traditional GT style turbos.
http://garrettbulletin.com/techcorner/garrett-by-honeywell-ball-bearing-turbochargers
Edited by juggernaut1
I asked FP this question about a year ago and did not get a direct answer. However, they did say the core is an off the shelf GT item and will be the same as what is found in a normal GT3076R.
Thus... Expect it to be a plastic cage.
I sent them an email today .......so will see if the response has changed. Am hoping they are using the gtx cores.
I was looking at the hta 3582 or hta 3586 for my G6E turbo. Otherwise the GTX 3576 would be a punchy performer on the falcon motor.
Unless you are ordering this as a 'highflow' alternative to slot into the OEM housing I would definitely be looking at something bigger. Even their 3786 I would say is a better option... Not to go back on the said theme of going 'bigger' but I am sure you could get a local turbo builder to reprofile the OEM housing to accommodate the GT37 turbine, too.
To me I see the barra as wanting a larger hotside than it has a compressor, so if to pick from a 3582 or 3586 logically my theory would say to pick the 3582... BUT results have indicated the 3582HTA packs the usual 3582 punch but sports response closer to that of a garden variety 3076R.
So... It seems like you want a smallish upgrade, but personally I don't think those turbos are good options for the barra. Maybe Lith can chime in and push a super 94 LOL?? Now that would be an interesting upgrade :)
Am unsure if the sheer efficiency of these turbos will mean the 4L motor maxes it out super early (caps power at a low rpm but spools mega quick) or if their said efficiency will mean it can cope.. Perhaps the fact they can cope with 5 bar PR will mean the later... Unsure.
I think HG has also done some XR6 stuff, maybe ask him for a link to some results by PM. (if serious about the small upgrade/highflow path)
Did you see my post a few back of the 3794R on the XR6? There are a few 450-550kw XR6T HTA3794 things lurking in Oz if I understand correctly
450 -500 is gtx 3582 territory on e85 on a stock ford and generally 400 plus on 98. In any case is far more than I am wanting from my daily which has to pull my boat.
Happy to step it down to the gtx 3576 for bit less.
I've reconditioned many XR6 BA turbochargers up to date, the highest power level I've seen was 430rwkws on E85 fuel. Probably because there are so many of them, I only found a small percentage of cars been modified. Out of the minority the average power level is between 330~360rwkws, many of them been autos.
On a Rb25det this turbocharger is horribly laggy, throttle response was poor, definitely nothing enjoyable for a daily.
Just for some fun, I dragged a close customer's R33 that currently has a GT3582R .82 turbocharger fitted, with my Kia sportage at his private run way at a farm yard. He's car is "said" to be tuned at 397rwkws, and my Kia has only 176fwkws. He wasn't been able to beat me till 140KM/H, and obviously at that point I could see him flying pass like a rocket.
The 3576 isn't much better then a 3582, which I originally thought it might pickup some response, the difference was very marginal, but it did pull 347rwkws on a stock manifold internally gated at 29psi.
I have finely tuned a ATR45 turbocharger (XR6 BA replacement) to work with a Rb25det, which I will use it for a base map running against those billet SS4 prototypes that I've made. At this point it is pretty derivable unlike the original item. I should have some results tomorrow, and very interested to see if HTA can tackle the lag issue better.
    • It's actually really good advice. And I do try to do it. I actually have 2x 3KG dumbbells that sit right beside where I sit. And I look at them a lot. Use them a little. But I'm trying to do more with it. At the moment I'm going through a heap of weight loss too which will help. I cracked into the 85kg mark this week. My weight used to have me sit consistently between 93 to 95KG! That definitely doesn't help. I've also got POTS, which flared up after I got slapped with COVID a few weeks back, and POTS really smashes fatigue and stuff into you, and has a thing even called "excercise fatigue". Basically even the minorest "excercise" (walking from the garage to the house) causes fatigue! And one of the treatments (Other than a med I'm on) is also... Excercise... Ha ha ha So it's why I'm trying to play the game of "might as well" and trying to push through things. For ADHD specifically, the general recommendation is "excercise". When you dig deep into it though, while any excercise is good, the best type is "explosive" excercise. So training for a sport like squash, tennis, even soccer. Things where you need to get the whole body able to "explode" into a different direction change. They've found with explosive sports, (I can't think of the proper term they have for it) that it actually makes the brain grow and become bigger in specific areas. The areas where ADHD causes those parts of the brain to be smaller than normal! But definitely, trying to push myself, and break those bounds mate, and get healthier!
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
