Yeah I doubt the FP Green BB even would be hugely lively under 4000rpm, it is still a fairly big turbo in effect - though in hindsight I have in my head FP will now upgrade any Mitsi based core to DBB, so something like a DBB 71HTA might be a nice balance
I don't think the 71 HTA would quite crack 300kw. :(
If they DBB the 71 HTA it would be great as they already have stock spool and flow 20% more than the stock 9 turbo. I woulda thought the green would be on before that?
Edited by Mick_o
Mick I'd say the 71HTA will flow 300kw :) The size would be 71mm compressor and 57mm turbine. Your GTX on the 33 was 71mm compressor and 60mm turbine, so its not majorly off!
Given enough wastegate flow I think you will get there and have nonsensical response. It may be worthwhile in modifying the toxicfab mani to accept two 38mm gates :)
I don't know for sure, would have to speculate really and I tend to lean on the edge of conservative.
I'd have picked the 71HTA to be capable of 310-330wwkw on E85, though yeah probably not 300+kw on pump gas.
The 73HTA I'd put as similar to a GT3076R, so 340-360wkw on E85, and the FP Green shouldn't be much different to an HTA GT3076R (370-390kw). That's what I'd be guessing anyway. Strictly speaking probably can't go far wrong with any of them, the 71 would probably be a bit mental haha.
In my opinion the housings and mainly the hot one are what sets the limits with these Evos when looking for more power . FP and a few other mobs do alternative compressor housings but there aren't that many direct fit turbine housings for them . I know someone with a 7 that has the 10.8cm one and reckoned it was a good looking thing internally . Mick you would know that MiVec 9s came with a 10.5 housing and it had the better waste gate system than the earlier twin disc ones like 6s had . The 10.8 looks like a slightly enlarged ported 9 one .
You have a significant advantage with a Mivec engine and I remember Mark at GT Pumps telling me that they feel a bit more like a non VCT stroker motor down low .
A .
I like mental Dan lol :)
Don't we all :D Maybe you should hit up the FP guys, but the way I picture it the 71HTA with DBB core could be a response monster with the ability to make decent power - probably not quite what your Skyline made, but it'd be real world very quick. Realistically, don't be a wuss and just get an FP Green HTA ... you have the cams for it, have some fun :)
  • Like 1
Hi everyone,
I'm trying to decide on a turbo, but not shore on what to use.
I've got a RB25DET that's going to be built for high hp, that the turbo would be going on. I'm planing on it to be auto & it will be going in a Vn commodore.
I was hoping to get somewhere about the 500kw mark out of it when it's finished. I don't want to run to much boost (22psi). If I need more boost I would rather go a bigger turbo ( just in case I want more power down the track ).
I was thinking on using the HTA SUPER 94 or HTA 3794R. Would it work with the t3 flange for the power I'm after, or would I have to go t4 flange (what sizes do they have, should I use a single or twin scrole housing).
What size pipe should I use for the manifold, because I would have to custom make it for my car (the rail on the car sticks out more & the engine mounts are different to that of a skyline)
Any help would be useful, thanks everyone.
Going up a turbo size also makes for a laggier setup, what is your issue with pushing a smaller turbo harder? A GTX35 could probably get you there.
You are pushing the engine hard, why not max out the turbo for best power available? Wastegates are overrated imo...
Hi everyone,
What fuel are you going to be using?
Sent from my GT-I9505 using Tapatalk 2
Makes a big difference in terms of what you choose. As a rough rule of thumb I guess I could say that you'd need to budget at least 20% more airflow potential for a pump gas turbo versus an E85 turbo hunting for the same power figures as a result of the ways they'd go about it - partly due to the boost limitation due to being much more likely to be knock limited with 98 RON fuel. If you are aiming for 500rwkw on 22psi using pump gas, you are going to need some REAL fancy parts - especially with stock displacement. The thing is going to need to rev, have awesome VE when doing so, be strong etc etc - the only people I know making that kind of power on pump gas are RB26 based with very large cams and turbos etc.
Off the top of my head I'd be leaning for at least a Super94 HTA for that power on pump gas, if not a 4294HTA... haven't put a huge amount of thought into it right now but at least as an educated thumbsuck - you are probably needing a 90+lb/min turbo to achieve that, and one which with a high flowing exhaust side (and exhaust system) to ensure the exhaust manifold pressure is as low as it possibly can be, you're going to need huge cams and to be able to get as much clean air into and out of the cylinders with each gulp. If you REALLY want that much power, I'd seriously consider just planning to run on high octane and find the stuff supplied if it is not at the pump.... your engine is likely to last longer, be more usable and generally easier to make the power with.
Not 100% sure, can try and find out need be - otherwise flick them a message on their Facebook page: https://www.facebook.com/FPTurbos?ref=ts&fref=ts
While on that topic, while it doesn't give specifics - here are a couple of interesting clips regarding the Super94 and 99 turbos:
Awesome!
Just because I don't know any background on you etc, and I am a big fan of making sure people know what they are getting into and getting the best out of their setup for what they are hoping for - FP do fantastic turbos for the cost, flow and response... but the Super94 is a BIG turbo in effect, don't let the T3 flange etc and not being a large frame turbo trick you - it will float somewhere between a T04Z and T51R Kai in terms of lag, probably closer to the T04Z but still.
On the flipside, it also is capable of making power up there with a T51R SPL - and given you are targetting in the region of 700whp on not huge boost using pump gas then you need a bunch of compressor, so hopefully you are prepared for the game to not really start getting exciting until around 5000rpm!
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
