All the air the engine consumes must come through the comp wheel. If the comp wheel can only flow "x" amount of air, that volume wouldn't change, or would it?
All being equal ( cams comp ratio etc etc ) a 2.6 will consume less air then a 3.0 which means the same turbo would have to spin faster to hold the same boost level on a 3.0, so while a comp wheel can only flow so much air the different size engine will pass more air
Which is the issue I'm having, 28psi through a 3.0 is to much air flow for the GT28 turbine side to pass creating to much backpressure
So a new late model EVO record has been set today - STM in the US raced their EVO 8 RS drag car which runs a .85a/r T3 Super 99 HTZ at Maryland International Raceway and started out the day running a loose 8.7 @ 181mph and gradually whittled the times down, first breaking the 4 year old record of 8.34 @ 169mph with a 8.28 @ 178mph - then taking it further down with a 8.09 @ 182.5mph with a 1.4s 60ft. It has definite 7s power, just needs to hook a bit better but probably less and less likely with the temps dropping quickly over in the US.
>180mph on a T3 turbo.... there are a lot of people who raise eyebrows at some of the dyno figures thrown around for some of these turbos, but that is HAULING!
  • Like 3
  • 2 months later...
Sorry to wake this thread up, just finished reading it all and have to say thanks for the information.
Has any of the builds in progress from last year come to any results?
Has anyone got specific results on rb25 hta3076 with hydraulic head?
Cheers
Cheers
Mines still coming along. Not too long it should be running but ive said that a few times now.
Cheers
Mine is still kicking :woot:
Looking forward to your results Brad. Even though my love for FP is all but gone :(
No FP love? :(
Dodgy designed turbo leaks oil like a tanker.
They won't warrant it as they dont make them anymore and they flat out blame the oil leaks on crank case pressure not their product.
Its a well known thing about them in the evo world.
I know of 4 other people with this issue with as little as 1500km on their turbos. Took my stock turbo to be modified at GT PUMPS & he currently has 4 of them that are leaking oil the only fix is to convert them to Journal bearing.
I spent $2700 on a turbo that done 3000km and isnt worth its weight in scrap :(
VERY disappointed as it took them months to build it and its f**ked in less time than it took to be built :(
Oh wow!
Never heard of that :domokun:
Sorry to hear mate... But at least you share your experience for others to see... I think FP are amazing based on my experience alone but its good to see both sides of the coin especially if people are looking to buy the same thing!
Thanks Matt oh well live and learn mate. I did love the turbos performance which is why it sucks so much!
It only seems to be a stock frame Mitsubishi issue.
The evo turbos they build run their own custom dual ceramic ball bearing cartridge which is the flop.
But turbos like Matts yeah they are a modified garrett basically with the HTA comp wheel :)
http://www.sau.com.au/forums/topic/453377-evo-9-turbo-kit-sydney/
Edited by Mick_o
Sounds like its isolated to just that style of turbo :( Dissapointing to say the least mate!
I wouldnt hesitate to buy another one through them due to my experience, but sucks to hear you had issues!
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
