On 15/02/2024 at 8:35 AM, Lithium said:
I'll have to get some logs when I do a little bit more work on an R34 GT-R I've been helping set up.
So we had a bit of a session today and didn't have much chance to test it perfectly for the point of this thread but the theme seemed to be it can hit 1bar close enough to 4000rpm in 3rd gear, give or take a little and man it feels a lot perkier between 3000-4000 than the -5s.
  • 4 weeks later...
I'll have to get some logs when I do a little bit more work on an R34 GT-R I've been helping set up.  Stock engine, 272deg cams, and a divided hotside Pulsar G35 900 with .85a/r T4 divided hotside and it drives fantastic - it's enough of an improvement over the old -5s that no data is really needed from our point of view to make a call on whether it's more responsive under foot to drive but boost threshold is always a handy metric.
I'm far from saying that the G35 would be a good choice for the kind of thing you're looking into, more what I'm suggesting is "G-series" turbos seem to respond very well to divided hotsides and middling a/rs (obviously ensuring that it's not so small as to choke the given setup).   If a static cam RB26 drives like this R34 does with a 80+lb/min turbo, then I can imagine a 60lb/min equivalent match on a VCT RB25 would be fantastic.
Interesting (but I suppose not massively surprising) the dyno plot doesn't put this car across as THAT much better down low than it was with the -5s, the old "transient response" beast back with a vengeance.  I guess you'll have to take my (and every other person who has been in or driven it) word that the car is a completely different beast now, feels WAY more alive basically everywhere.   Holds power better, "wakes up" faster under foot.  It's generally a significantly faster and better car to drive, beyond what the plot shows.
Anyway, only changes here are swapping from low mount -5s to a Pulsar G35 900, and from a stock Nissan RB26 intake manifold to a Hypertune single throttle jobby.   On the dyno pull it doesn't really pick up noticeably harder until it's got about 10psi into it, then it gets from there up to target boost a good 500rpm earlier.
Same boost, same fuel (98 pump gas), same dyno:
Note: This is both 22psi.  It's a stock RB26 aside from cams, the turbo was chosen for headroom - and there should be HEAPS in it with a built engine and ethanol flowing through it's veins.
Edited by Lithium
  • Like 2
This is what I was getting to with regards to the whole N/A V8 thing. A dyno shows the result as much worse, but in terms of how 'alive' the car feels afterwards, it's night and day, better in every way, there's no copium, I prefer my 280kw setup over my 430kw setup.
This was me doing predictions before I did the swap, I make about ~10kw more everywhere than the blue line, but chalk and cheese in terms of liveliness. I understand what Lithium is trying to say with his dyno graphs that look mostly the same in his case, but one is vastly superior in the real world. The blue line looks laughably bad on the dyno graph in my case, which really highlights the point.
People absolutely, absolutely, completely underrate how important transient response is to how much fun a car is, how it feels, and how much you can trust a car, which means you can drive the thing faster, and if you are going faster and using 70% of the throttle, and trusting, and pushing, it's a far more fun, complete, and faster experience than feeling like you can't go beyond 50% of your throttle use but damn your dyno plot looks great.
  • Like 5
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
