GOD DAMMN IT MATT.
Stop making me jealous. Haha
That's awesome to prove the non believes on just how awesome these FP hta turbos are. I'm still saving for my 6booba and hta 3073 iss the plan at the moment. :)
I wonder what the difference would be between there 76 and 73.? Only want to really try the 73 to be different.
Josh.
I was 50/50 on the 3073 vs 3076 as response was something my car was lacking with the old setup, i do not regret the 76 choice one bit but i do really hope you go the 3073 as i have been dying to know what they will do :P
Decide exactly what you want first, getting the 73 just to be different is quite an expensive exercise for not a huge amount of reward. If you really want the extra response vs power then it will be quite a beast - realistically I'd guess it will get you into the same power area as a vanilla GT3076R (350-360rwkw on the right setup), I wouldn't count on any more.... however the response will probably be pretty intense!
Yeah i think the response on the 3076 version is perfect for what i am doing... Any more would just be nuts! haha
Mark at GT Pumps has some dealings with FP , may be worth while asking him if he can make you up a 73 or 76HTA GT30 turbo .
I need to ask him if he can do a HTA but with a T04E compressor housing , I reckon the bigger 0.70 AR S housing is a bit bulky for a 71 or 73mm comp size turbo . I know it's not the same thing but Garrett seem to be able to make reasonable power with GTX71 wheels in 0.60 AR T04E housings , the issue probably is that port shrouded T04E housings are thin on the ground except on GT30 BB turbos .
A .
GOD DAMMN IT MATT.
Josh.
I'm not sure whether the HTA 73 is similar to the 3076 52 trim - but FWIW I changed from a 3071 to a 3076 52 trim - both with the .78 twin scroll rear on an SR20 and found the baby 3076 to be far more responsive than the 3071. However my caveat is that I had replaced the 3 inch dump and exhaust for a 3.5 inch dump and exhaust when fitting the baby 3076.
Ill post proper graphs etc when i get time but for now these are just screen shots from Saturday when we were troubleshooting the ign problem, not bad considering the car was running on the dyno for ages and just kept pulling the numbers consistanty, these are not peak runs, just standard power runs while checking stuff, so this is as it would run on the street with full trim -
On the Dyno -
Low Boost -
High Boost -
Posting for updates. :)
Where is everyone getting there HTA wheels from? States or someone in Australia?
Lol updates will come soon from mine, not sure where the others are up too.... From what i know there were a couple of others keen on the HTA but not sure who has commited too it!
I ordered mine direct from Forced Performance.
How long did it take to arrive?
I dont know if there are any dealers in australia.
Mark at gtpumps deals with FP a bit though so maybe flick him an email?
As far as i know there are no Aussie dealers, i looked long and hard and ended up just going direct to FP as they were helpful and i guess i knew i was getting a genuine product and not some slap together turbo!
Back on the dyno today to finish off my tune and test for exhaust restrictions.
Made 436rwkw with the exhaust dropped at the dump pipe ( which is 3.5" from turbo) , and made 434rwkw with the full exhaust (which is only 3" from dump pipe back.
Picked up a few kw and got a flatter power curve setting u the autronic boost controll to add a bit of boost to the higher rpm, from memory it was making over 425kw from 6000rpm to 8000rpm, which should help drag times a bit will post graph later.
Edited by sky30
Looking forward to seeing the graph!!! Awesome :yes:
Wow nice power curve - how much boost, when did it make full boost, and what fuel is that on?
On the road (bit more load) it reaches 20psi at 3200rpm on the autronic logs.
I Was running 24-25 psi increasing to 26psi in the higher revs after peak torque, using bp 98 with a bit of water meth injection.
I will have to do a log to see what rpm 26psi is id guess 3300-3400.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
