AS FOR YOU CO*K HEAD WATCH WHAT YOU TYPE!
I think it was a pretty fair call in terms of what he meant, it's pretty low to take a company that has put thousands of hours into R&D and proven results and then just copy the design to save a few dollers... Stao was pretty clear in his statement and i think he was pretty fair too!
Stao you should try create some new wheels that match ir beat the hta comp wheels as Lithium mentioned. I always prefer to go local if I can. I just dont know what to do im not using the plain new gt3076 I have in the shed.
Don't drip stuff which is not relevant to this thread into it - this is about FP HTA turbos, not Hypergear, and not anyone copying or trying to compete with HTA. A relevant comparison (whether the HTA or the competitor outperforms doesn't matter - just something informative) would be good, be very interesting to get a Hypergear vs HTA comparison on the same dyno and setup for example... but otherwise, its just spam.
Get in touch with FP, or GTPumps - Josh.... pretty sure GTPumps do hybrids using HTA compressors, so maybe able to help.
Would the quality and response of the GTpumps match with what FP are doing. Otherwise it would probably be worth it to just go straight to FP
The extra bit of boost is worth it in the mid isn't it. Must be impossible to keep it stuck down.
A lot of extra boost for not much gain... Honestly on 20psi its enough of a handful :D
I find it interesting that FP no longer offer twin scroll housings........
In other news - FP have released a Super 99 HTA turbo, a 103lb/min T3 flanged (hopefully they release other flange versions - but still) turbo capable of >1000hp. MENTAL!
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFPSUPER99&Category_Code=Turbo-FP
Oh, right... when the SUPER 94 isnt enough... lol :woot:
Edited by Tonba
The super 94 is never enough! I am thinking of a super 99 for the van :P
34geetee, pitty it wont hold boost, what boost control you have?
Can make it hold boost if we really wanted too but no point creating the extra heat etc....
Adam explained it too me but it was over my head, i just smiled and nodded lol.... Basically it was done for longevity of the turbo and engine....
I had HKS EVC 5 and now Greddy Profec B II, funnily enough despite what all the reviews say the Greddy is better than the HKS on my car!
Matt cant your haltech control boost as well? May I ask why you use the greddy?
Josh
Yes the haltech can if the solenoid is added, we have always stuck with external boost control though, it was a decision made during the build and there was reasoning, i cant remember what it was though lol
Interesting - when I was looking around at boost controllers I found the Blitz Dual SBC seemed to be the overall best respected by people I trusted. With my playing around with cars so far I by far like "decent" aftermarket ECU in-built boost control setups... ie, the G4 Link boost control has been brilliant for me and I'd assume the Haltech would be no worse. Why not use that?
I honestly dont remember man, it was a reason that i just cant recall lol
    • To be determined, Luke, to be determined. 馃榿 Definitely the car
    • It might be worth having a good look at the chassis behind the bumper then; most people prefer the series 2 look so it might have been changed to cheaper parts as part of an earlier repair
    • The car itself a series 2. I was just curious about the headlights and just wanted to confirm that they were series 1. Good to know the rest of the front end is series 1. It鈥檒l be easier for me to find parts on the aftermarket side of things lol
    • If you've wired up the coils & injectors properly, & have the neo CAS loom for the trigger, it should all work. The VCT works the same way so just different plugs between s1 & neo. Assuming DBW if no IAC. Don't bother with the stock boost solenoid with g4x.
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
