Because going straight to a 94HTA might be too much of a jump in one shot? ;)
LOL no no, because of a reason he can't recall :P
Why not super 99? Because of reason cannot recall.
I find it interesting that FP no longer offer twin scroll housings........
E85 and other variants have probably reduced the dependency on twin scroll systems somewhat. This and twin scroll setups are still likely to cap peak outputs....which is no good from a marketing point of view.
Still prefer a twin scroll setup myself on a street car - coupled with E85.
Yeah, me too. My RB based dream build is pretty much an R33 GTR with an RB30/26 and a TS 3794HTA on the side of it - the concept seems like good thing I get probably a little too happy just thinking about it hahaha
Lol you clowns haha
You get that, because of a reason I can't recall ;)
LOL that's the spirit.
P.S. I would say we dream about the same things, but if you were dreaming about my wife I would be worried. So for now it will have to be just our R33 dreams, for reason I can't recall.
I cant recall how this all started..... But git farked :P
Quick question - does anyone know whether the HTA turbos use the Garrett cores with the metal bearing cages which I understand are used in the GTX turbo's or the plastic bearing cages as typically found in the traditional GT style turbos.
http://garrettbulletin.com/techcorner/garrett-by-honeywell-ball-bearing-turbochargers
Edited by juggernaut1
I asked FP this question about a year ago and did not get a direct answer. However, they did say the core is an off the shelf GT item and will be the same as what is found in a normal GT3076R.
Thus... Expect it to be a plastic cage.
I sent them an email today .......so will see if the response has changed. Am hoping they are using the gtx cores.
I was looking at the hta 3582 or hta 3586 for my G6E turbo. Otherwise the GTX 3576 would be a punchy performer on the falcon motor.
Unless you are ordering this as a 'highflow' alternative to slot into the OEM housing I would definitely be looking at something bigger. Even their 3786 I would say is a better option... Not to go back on the said theme of going 'bigger' but I am sure you could get a local turbo builder to reprofile the OEM housing to accommodate the GT37 turbine, too.
To me I see the barra as wanting a larger hotside than it has a compressor, so if to pick from a 3582 or 3586 logically my theory would say to pick the 3582... BUT results have indicated the 3582HTA packs the usual 3582 punch but sports response closer to that of a garden variety 3076R.
So... It seems like you want a smallish upgrade, but personally I don't think those turbos are good options for the barra. Maybe Lith can chime in and push a super 94 LOL?? Now that would be an interesting upgrade :)
Am unsure if the sheer efficiency of these turbos will mean the 4L motor maxes it out super early (caps power at a low rpm but spools mega quick) or if their said efficiency will mean it can cope.. Perhaps the fact they can cope with 5 bar PR will mean the later... Unsure.
I think HG has also done some XR6 stuff, maybe ask him for a link to some results by PM. (if serious about the small upgrade/highflow path)
Did you see my post a few back of the 3794R on the XR6? There are a few 450-550kw XR6T HTA3794 things lurking in Oz if I understand correctly
450 -500 is gtx 3582 territory on e85 on a stock ford and generally 400 plus on 98. In any case is far more than I am wanting from my daily which has to pull my boat.
Happy to step it down to the gtx 3576 for bit less.
I've reconditioned many XR6 BA turbochargers up to date, the highest power level I've seen was 430rwkws on E85 fuel. Probably because there are so many of them, I only found a small percentage of cars been modified. Out of the minority the average power level is between 330~360rwkws, many of them been autos.
On a Rb25det this turbocharger is horribly laggy, throttle response was poor, definitely nothing enjoyable for a daily.
Just for some fun, I dragged a close customer's R33 that currently has a GT3582R .82 turbocharger fitted, with my Kia sportage at his private run way at a farm yard. He's car is "said" to be tuned at 397rwkws, and my Kia has only 176fwkws. He wasn't been able to beat me till 140KM/H, and obviously at that point I could see him flying pass like a rocket.
The 3576 isn't much better then a 3582, which I originally thought it might pickup some response, the difference was very marginal, but it did pull 347rwkws on a stock manifold internally gated at 29psi.
I have finely tuned a ATR45 turbocharger (XR6 BA replacement) to work with a Rb25det, which I will use it for a base map running against those billet SS4 prototypes that I've made. At this point it is pretty derivable unlike the original item. I should have some results tomorrow, and very interested to see if HTA can tackle the lag issue better.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
