Yeah I doubt the FP Green BB even would be hugely lively under 4000rpm, it is still a fairly big turbo in effect - though in hindsight I have in my head FP will now upgrade any Mitsi based core to DBB, so something like a DBB 71HTA might be a nice balance
I don't think the 71 HTA would quite crack 300kw. :(
If they DBB the 71 HTA it would be great as they already have stock spool and flow 20% more than the stock 9 turbo. I woulda thought the green would be on before that?
Edited by Mick_o
Mick I'd say the 71HTA will flow 300kw :) The size would be 71mm compressor and 57mm turbine. Your GTX on the 33 was 71mm compressor and 60mm turbine, so its not majorly off!
Given enough wastegate flow I think you will get there and have nonsensical response. It may be worthwhile in modifying the toxicfab mani to accept two 38mm gates :)
I don't know for sure, would have to speculate really and I tend to lean on the edge of conservative.
I'd have picked the 71HTA to be capable of 310-330wwkw on E85, though yeah probably not 300+kw on pump gas.
The 73HTA I'd put as similar to a GT3076R, so 340-360wkw on E85, and the FP Green shouldn't be much different to an HTA GT3076R (370-390kw). That's what I'd be guessing anyway. Strictly speaking probably can't go far wrong with any of them, the 71 would probably be a bit mental haha.
In my opinion the housings and mainly the hot one are what sets the limits with these Evos when looking for more power . FP and a few other mobs do alternative compressor housings but there aren't that many direct fit turbine housings for them . I know someone with a 7 that has the 10.8cm one and reckoned it was a good looking thing internally . Mick you would know that MiVec 9s came with a 10.5 housing and it had the better waste gate system than the earlier twin disc ones like 6s had . The 10.8 looks like a slightly enlarged ported 9 one .
You have a significant advantage with a Mivec engine and I remember Mark at GT Pumps telling me that they feel a bit more like a non VCT stroker motor down low .
A .
I like mental Dan lol :)
Don't we all :D Maybe you should hit up the FP guys, but the way I picture it the 71HTA with DBB core could be a response monster with the ability to make decent power - probably not quite what your Skyline made, but it'd be real world very quick. Realistically, don't be a wuss and just get an FP Green HTA ... you have the cams for it, have some fun :)
  • Like 1
Hi everyone,
I'm trying to decide on a turbo, but not shore on what to use.
I've got a RB25DET that's going to be built for high hp, that the turbo would be going on. I'm planing on it to be auto & it will be going in a Vn commodore.
I was hoping to get somewhere about the 500kw mark out of it when it's finished. I don't want to run to much boost (22psi). If I need more boost I would rather go a bigger turbo ( just in case I want more power down the track ).
I was thinking on using the HTA SUPER 94 or HTA 3794R. Would it work with the t3 flange for the power I'm after, or would I have to go t4 flange (what sizes do they have, should I use a single or twin scrole housing).
What size pipe should I use for the manifold, because I would have to custom make it for my car (the rail on the car sticks out more & the engine mounts are different to that of a skyline)
Any help would be useful, thanks everyone.
Going up a turbo size also makes for a laggier setup, what is your issue with pushing a smaller turbo harder? A GTX35 could probably get you there.
You are pushing the engine hard, why not max out the turbo for best power available? Wastegates are overrated imo...
Hi everyone,
What fuel are you going to be using?
Sent from my GT-I9505 using Tapatalk 2
Makes a big difference in terms of what you choose. As a rough rule of thumb I guess I could say that you'd need to budget at least 20% more airflow potential for a pump gas turbo versus an E85 turbo hunting for the same power figures as a result of the ways they'd go about it - partly due to the boost limitation due to being much more likely to be knock limited with 98 RON fuel. If you are aiming for 500rwkw on 22psi using pump gas, you are going to need some REAL fancy parts - especially with stock displacement. The thing is going to need to rev, have awesome VE when doing so, be strong etc etc - the only people I know making that kind of power on pump gas are RB26 based with very large cams and turbos etc.
Off the top of my head I'd be leaning for at least a Super94 HTA for that power on pump gas, if not a 4294HTA... haven't put a huge amount of thought into it right now but at least as an educated thumbsuck - you are probably needing a 90+lb/min turbo to achieve that, and one which with a high flowing exhaust side (and exhaust system) to ensure the exhaust manifold pressure is as low as it possibly can be, you're going to need huge cams and to be able to get as much clean air into and out of the cylinders with each gulp. If you REALLY want that much power, I'd seriously consider just planning to run on high octane and find the stuff supplied if it is not at the pump.... your engine is likely to last longer, be more usable and generally easier to make the power with.
Not 100% sure, can try and find out need be - otherwise flick them a message on their Facebook page: https://www.facebook.com/FPTurbos?ref=ts&fref=ts
While on that topic, while it doesn't give specifics - here are a couple of interesting clips regarding the Super94 and 99 turbos:
Awesome!
Just because I don't know any background on you etc, and I am a big fan of making sure people know what they are getting into and getting the best out of their setup for what they are hoping for - FP do fantastic turbos for the cost, flow and response... but the Super94 is a BIG turbo in effect, don't let the T3 flange etc and not being a large frame turbo trick you - it will float somewhere between a T04Z and T51R Kai in terms of lag, probably closer to the T04Z but still.
On the flipside, it also is capable of making power up there with a T51R SPL - and given you are targetting in the region of 700whp on not huge boost using pump gas then you need a bunch of compressor, so hopefully you are prepared for the game to not really start getting exciting until around 5000rpm!
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
