Yeh im in canberra. Surely there is someone on evo oz up your way that can take you for a fang! The hks evc on my car is playing up at the moment because of the way its wired in (ecu 12v source), so as soon as the car has decent load the power gets cut to the boost controller and the waste gate opens and feels like the car just shat the bed.
What was your power goal mick?
Edited by Mitcho_7
Im hoping there ain't any evoOz guys in here lol but I find a majority of them to be *toolscough* so don't really use that site anymore. Im only looking at the most responsive 300-330kw I can get with a stock framed turbo on E85 of course.
The green with like 28-30psi should get you into 300s with plenty of torque, the red definitely will with less boost but will give less torque as well. The red would be a street weapon on a 2.3L
All I can say is if I had the choice again id go the bb green
  • Like 1
Mick O, your 33GTST was da 'bomb, it was an ultimate rwd streeter. Is the evo 9 much of an upgrade except for the awd? If it was me I wouldnt sell that 33 except if I really had to get an R, just sayin..
Haha thanks Ron it was an epic car and i do miss it :( It just really hauled ass lol!
Yeah the evo is a great car doesnt go like my 33 did (yet) but for corners and just being a great fun drive id say definitely an upgrade :) name="rondofj" post="7052746" timestamp="1380934387"]Mick O, your 33GTST was da 'bomb, it was an ultimate rwd streeter. Is the evo 9 much of an upgrade except for the awd? If it was me I wouldnt sell that 33 except if I really had to get an R, just sayin..
I'm pretty keen to chuck a HTA 3076 on my R34, does anyone have any idea how much modifying it would take to get it to bolt to the standard manifold? For example I've been looking at a GTX3076 and it's gunna cost around $1200 to modify things like spacer plate, dump pipe, intake pipe etc. as this is based on the garret turbos am I going to be looking at exactly the same costs?
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
