Best results seem to favour the turbo housing, as long as the gate can get good flow. I managed to help squeeze 430kw out of the factory manifold using a gate off the housing.
Welding the the manifold makes it too hard to clean up the inside with a die grinder afterwards. You can't just weld a gate on at a 90 and expect it to flow well.
Housing sounds good. Preparing to invest in a HTA 3076 :turned:
Obviously staying low mount for a more standard appearance but wanted to know many people are going that way.
Any idea what kinda of power I could push with one running 16-20psi with supporting mods? Car's a 33 GTST. I'm still running standard head gasket but previous owned had forged motor built. So I'm not sure how much boost I can push.
Edited by GotsWapan
Depends on your choice of fuel mate :)
An FP3076HTA is a lot of turbo for BP98 and stock exhaust manifold etc. Be sure that it's definitely the turbo that is holding you back in power, otherwise you could spend a lot of money and not get the kind of return you want... or expect.
No worries. I appreciate the input. Been having dramas gettin decent power becuase I cheaped out in the first turbo I bought for it.
Whats on it now?
Tuners are always fond of pointing the finger at a turbo, even the best tuners I've used will do it. Maybe describe what you have (if its still on there) and we can give some pointers in relation to what it should be doing and where it may have gone wrong?
Its a GTX3076R with a 0.82 rear housing with standard dump pipe flange. I've been told they're no good for flow by a few members on here. Can you confirm or correct this please :happy: I'm aiming upwards of 280rwkw
I'm only making 220rwkw at 16-18 psi
Edited by GotsWapan
Wtf. What engine is that on? And what standard dump pipe flange? While I prefer the HTA turbos... A GTX3076R should be yawning at that power level, this is definitely sounding like a case of working out what isn't working the way it should. I wouldn't spend a lot of money swapping turbos at this stage
Sent from my GT-I9505 using Tapatalk
RB25DET Built with Nitto/JE Pistons and rings and spool rods. All bottom end was assebled professionally with Reco'd head. Boostn Imports was selling kit a while ago that came with a Sonic/MTQ rear housing that bolts to the standard dump pipe, internally gated of course. I was silly and didn't do my research and I cheaped out and bought it.
Other mods are full 3" exhaust, 600x300x80mm cooler, button clutch. ECU is a Wolf 3d V4. Fuel is with 044 and Nismo 740cc injectors.
I thought I bought all the correct supporting mods but I think its the turbo holding it back.
Edited by GotsWapan
No way that it's the turbo holding you back. Might be your standard dump. Is your Cat a highflow aswell I knocked mine out and got 280kws at 16psi with boost tapering off to 12.Clutch was slipping too. With a stock engine.
As others have said no way it's the turbo.
With a R33 highflow.
Its a full 3" similar to a JJR one. I'm sort of lost in what to do now. Cat is a stainless 3" good quality one
Even Ash R31 Nismoid suggested it was a rubbish housing.
The car makes no more power after 6000rpm
Edited by GotsWapan
Definitely the housing mate you will probably find its a .70 and not a .82 as suggested..I was offered the same housing on my GTX3071 and ditched it for a garrett housing my car went onto make 288kw on 98 and 336kw on E85. I can 100% assure you that's the issue might be up for cool grand for a .82 garrett rear and a new dump pipe plus a tickle up on your tune but that's less than half the price of the turbo.. Maybe a bit more if ya not handy on the tools :yes:
Thanks, now thats been confirmed. Would you suggest the 5 bolt genuine garret IW or a 4 bolt external with wastegate setup? The only reason I ask is that I've heard sometimes the wastegate flapper on the housing sometimes need machining for higher boost.
I had 5 bolt genuine garrett IWG with 14psi actuator and it held 25psi with a good EBC fine boost dropped to 23 up top but that's cause the turbo was maxed out. IWG will be cheaper and easier to set up and will probably still net ya 280kw easy
  • Like 1
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
