CAN I PLEASE ASK A MODERATOR TO PLEASE REMOVE MY COMMENTS TO JACKY CHAN ON PAGE 30.
CAN THESE PLEASE BE DONE ASAP
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/page-30
THANKS
The gtx does use metal cages, but the hta turbos are based off standard Garrett turbos
The Garrett based HTA turbos are based on Garrett cores, however the "FP" DBB turbos have metal cages - that covers the FP Green, Red, Black, Super94 and Super99 :) No doubt you can get the Garrett based ones with metal cages as well
Are the metal cages just for longevity? I know mine sure cops a lot of heat :ph34r:
Yep, is a durability thing. Though there are more than enough plastic cage GT users (my brother included) who have never had an issue.
Don't worry, just retain warranty information :)
Yeah have got all that ;)
I dont foresee any issues with the turbo i guess.... I would guess the thing copping the boost would let go first :laugh:
LOL possibly.
It should also be noted that Simon saw the same issue with his GT's that he did with the GTX that replaced it. I'm sure you saw the recent thread on that, so meh.
LOL possibly.
Nope? :blink: Link?
Strangely enough thinking about it I know of hardly any GT-series based HTA turbo failures - not sure I definitely know of any, and I know of quite a number which have been used for track racing etc. Like usual, it'll be heat that causes any major issues.... odds are if its not on high boost and it's not sustaining heavy thrashing for a long time there (hopefully) won't be an issue. Touch wood, it's be fine so far!
In 34GeeTeeTee's case I suspect the stock motor is the bit we should be more worried about :/
Haha it's had a good innings so far and will continue to get driven they way it should :P
Plenty of events coming up this year! I really should invest in a back up now i mention that!
Nope? :blink: Link?
Come on dude, I thought you were an enthusiastic forum member! Can't be falling behind like this LOL
http://www.skylinesaustralia.com/forums/topic/439625-dead-turbo-vid-inside/
Lith you are probably on the money (at least in my own mind). Hand in hand does pound for pound improvement go with improved efficiency, which is translated in lower charge temp and subsequent EGT. I would say the ratio of shaftspeed to flow at the compressor side has been engineered to benefit hotside flow, which would also greatly benefit.
All in all they are superior turbos, and likely to have better lifespan as a result.
Well there you go eh? :laugh:
I was off the forums for a while man, am hopefully back to make an ass of myself once again :yes:
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
