I figure if an Evo TD0516G can do 206 kw two may work in the right housings .
To make a GTX67 with the 90 trim cropped turbines it's probably easier to start with a 2867 cartridge and exchange turbines .
If you're going to use GTRS comp housings make sure you get cartridges with the 52T 71mm GT compressor because that what GTRSs have .
A .
  • 4 weeks later...
A few of you know about the problems and stress I had with Jacky Chan from CJ Motor when I bought my HTA turbo from him.
When I spoke to Mike the Manager from Forced Performance he told me they only had one official distributor here in Australia. Charles from Lamspeed. I was in contact with Charles a few times, he is helpful and knows his stuff.
If you are thinking of buying one of these turbos I would either buy directly from Forced Performance or if you want buy local use Charles from Lamspeed.
This is why i went direct!
  • Like 1
What was the result in the end if you don't mind me asking? Did you sort out the turbo/money? I know it's not right to be talking negatively about a workshop/supplier but if they are down right scamming people then fair play I say
Yeah try not to name names or put shit on workshops on the forum, it always ends up badly... Feel free to elaborate just dont put names etc on it if you can avoid it!
Or PM each other if you feel the need...
  • 3 weeks later...
FP have been pretty busy, looks like a bunch of their range has been getting a bit of a make over - the HTA3076 and HTA3582 now have custom antisurge FP compressor covers with 3.25" intakes, and also their own turbine housing options, the HTA3076 has a .73a/r option, and the already known of .85 option for the GT3582R.
Still hoping to hear results for the 6466TZ, though the HTZ range is growing - Rob has already confirmed a 79HTZ compressor and there are potentially others coming along soon.
The new HTA3076s look like this: 84GT761.jpg
Yeah its the super 94 twin scroll, the motor should be nearly finished by lewis maybe 2 more weeks then shipped to gold coast to be fitted and a run in tune so should be running within a month but I work away so its a pain in the ass trying to organize stuff but getting closer now, heres some more hta porn
Can't wait to see how this beast goes?
  • Like 1
Not the prettiest looking thing :P
Just made a build thread so you can keep updated
  • Like 1
Haha, was going to wait till its sorted and run all in.... also been bloody busy lately.
Spool seems more or less PT6466 spool Whig is a good start. If it lives up to the HTA 3794 flow numbers then it's a damn good thing
  • 1 month later...
  • 4 weeks later...
Just a bit of a FYI, while I was discussing turbo options for a mate I was pointed at this - Owen Developments in the UK are partnered with FP and given they have an aftermarket more like ours, the range of FP HTA/HTZ based turbos they have are probably more relevant to NZ and Oz. Here are some which may be particularly interesting here:
This beasty I reckon could be a neat "next step up" for those who an HTA3076 isn't quite enough but full GT3582R type madness is a bit too much:
HTA2865: http://www.owendevelopments.co.uk/product/430/Owen_Developments-Garrett_ODGT2865HTA/
^ This and the HTA2868 for GTRs and Silvias... tbh I'd be particularly interested in the HTA2865 in twin form, not sure how it'd go but the 2868s have apparently worked well but I'd consider them a bit on the large side for most people's taste - especially with that turbine.
HTA3073: http://www.owendevelopments.co.uk/product/429/Owen_Developments-Garrett_ODGT3073HTA/
^ This one should need no introduction, has been discussed but there has been question on if it is still done. It is, apparently :)
The FP Zephyr HTZ compressor on a GT35 turbine, guessing this would be a very nice and probably better matched alternative for those who would otherwise consider a GTX3576R - HTZ3579: http://www.owendevelopments.co.uk/product/389/Owen_Developments-Garrett_ODGT3579HTA/
These all have steel bearing cages, too.
  • Like 2
I think the HTA2865 would be good on a 2.8, but a touch big for a 2.6 and the turbine a touch small for a 3.0, I would like to see a HTA3068 as a bolton for those of us with 3.0 cause IMO the 28 turbine becomes a restriction when you get into the mid-high 20 psi range
  • Like 1
If a 2.6, 2.8 or a 3.0 are making say 700 hp, would exhaust has volume be any different?
If everything downstream of the engine provides the same resistance to a given amount of flow, but the engine itself provides less resistance to whatever is pumping into it (ie, turbos) then there becomes less intake pressure versus exhaust pressure... which happens to be one of the bigger influences on volumetric efficiency.
I could be wrong, but there may be an answer to our turbine issues soon...
All things been equal I believe so but there are to many variables like engine efficiency etc
The 3 would also be doing it at different RPMs as they flow different amounts at the same RPM which was my point, a 3.0 at 8000rpm flow a fair bit more then a 2.6 at the same rpm and even more when you start puming 28psi of boost pressure into it
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
