All the air the engine consumes must come through the comp wheel. If the comp wheel can only flow "x" amount of air, that volume wouldn't change, or would it?
All being equal ( cams comp ratio etc etc ) a 2.6 will consume less air then a 3.0 which means the same turbo would have to spin faster to hold the same boost level on a 3.0, so while a comp wheel can only flow so much air the different size engine will pass more air
Which is the issue I'm having, 28psi through a 3.0 is to much air flow for the GT28 turbine side to pass creating to much backpressure
So a new late model EVO record has been set today - STM in the US raced their EVO 8 RS drag car which runs a .85a/r T3 Super 99 HTZ at Maryland International Raceway and started out the day running a loose 8.7 @ 181mph and gradually whittled the times down, first breaking the 4 year old record of 8.34 @ 169mph with a 8.28 @ 178mph - then taking it further down with a 8.09 @ 182.5mph with a 1.4s 60ft. It has definite 7s power, just needs to hook a bit better but probably less and less likely with the temps dropping quickly over in the US.
>180mph on a T3 turbo.... there are a lot of people who raise eyebrows at some of the dyno figures thrown around for some of these turbos, but that is HAULING!
  • Like 3
  • 2 months later...
Sorry to wake this thread up, just finished reading it all and have to say thanks for the information.
Has any of the builds in progress from last year come to any results?
Has anyone got specific results on rb25 hta3076 with hydraulic head?
Cheers
Cheers
Mines still coming along. Not too long it should be running but ive said that a few times now.
Cheers
Mine is still kicking :woot:
Looking forward to your results Brad. Even though my love for FP is all but gone :(
No FP love? :(
Dodgy designed turbo leaks oil like a tanker.
They won't warrant it as they dont make them anymore and they flat out blame the oil leaks on crank case pressure not their product.
Its a well known thing about them in the evo world.
I know of 4 other people with this issue with as little as 1500km on their turbos. Took my stock turbo to be modified at GT PUMPS & he currently has 4 of them that are leaking oil the only fix is to convert them to Journal bearing.
I spent $2700 on a turbo that done 3000km and isnt worth its weight in scrap :(
VERY disappointed as it took them months to build it and its f**ked in less time than it took to be built :(
Oh wow!
Never heard of that :domokun:
Sorry to hear mate... But at least you share your experience for others to see... I think FP are amazing based on my experience alone but its good to see both sides of the coin especially if people are looking to buy the same thing!
Thanks Matt oh well live and learn mate. I did love the turbos performance which is why it sucks so much!
It only seems to be a stock frame Mitsubishi issue.
The evo turbos they build run their own custom dual ceramic ball bearing cartridge which is the flop.
But turbos like Matts yeah they are a modified garrett basically with the HTA comp wheel :)
http://www.sau.com.au/forums/topic/453377-evo-9-turbo-kit-sydney/
Edited by Mick_o
Sounds like its isolated to just that style of turbo :( Dissapointing to say the least mate!
I wouldnt hesitate to buy another one through them due to my experience, but sucks to hear you had issues!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
