Depends on where you want to compromise and what you think you will get the most reward from, you can definitely save a reasonable amount of money and still get respectable performance - however with this there is less risk you are going to look back and think... Maybe this could be better, but now I have spent the money.
Sent from my GT-I9505 using Tapatalk 2
Hehe sounds familiar :ph34r:
And if the Mat now could talk to the Mat who was angsting about whether to spend that money, what would you tell yourself?
STFU and buy it!!! ;)
Yeah power to the ground and I can't get full bore with 245 Michelin PSS and supposedly 271 at the wheels .
My gut feeling is that the 3073HTA in an 82 housing should be a good all rounder in an RB25 provided you don't mind having what looks like a GT3582R under the lid .
A .
harden up princess, buy wider tyres. 245 wide was so 1993
:laugh:
I stick to 265/35 as its close enough to stock speedo reading! AND at 390kw power to the ground doesnt happen..... At 360ish you can get it to grip up at the start of third if you mash the pedal from the get go..... So at 271 there is no excuse OR poor suspension setup...
Yep, I ran 255s on the back of mine and at the ~270kw area it was fine - maybe you could feel the tyres struggling a bit in 2nd, but only enough to make it obvious they were earning their keep.... nothing that required lifting of the throttle to let hook up or anything, unless it was wet.
I can't think of a better tyre than a Michelin PSS.... The traction issue described is far from a fault of the turbo or the tyre (size/make)..
Definitely a fault of the current alignment (or lack thereof)
So are all atp housings crap or is it a hit and miss affair?
People have had mixed bag with their luck with them - so far anyone I have heard of (including on forums) I know who have had issues are ones who have been running the turbo HARD. One of my mates has been running his EVO with an ATP TS 1.06 HTA3582 on pump gas for years (~330-360awkw max) as a time attack/hillclimb car with no issues. That case I showed was actually the only case I know of first hand, no one else I know has had a specific issue - and that car had been run to >500kw @ hubs on an SR20VET with a GT35 hotside and typically raced at race events (not time attack, actual laps) at >400kw so it was pushed pretty hard.
Not saying it WILL happen, but the potential is there.
:laugh:
fo sure!
I keep hearing the same bs about not being able to get traction from a sub 250kW car, it's becoming a broken record disco, get wider tyres, fix up your dated suspension and stop mentioning you have no traction.
There are plenty of guys making over 300kW and I never hear them having traction issues.
fo sure!
This exactly.
I had 266kw and coming on boost in 2nd it would spin my Kumho 245 KU39's (comforty/sporty) tyres pretty hard. The car would snap out to 45 degrees, and bash the limiter and go nowhere really,
Then I got pineapples fitted and Nitto Invo's at the rear in 255 when the setup changed a bit and now it doesn't spin 304kw when the rubber is warm.
The setup is king.
A decent diff helps too, the viscous LSD is a piece of poo, as it's a viscous coupler there will be always some element of slip between both wheels.
Correction. As it's a viscous coupler there will always be a shit load of slip between the wheels as soon as you have more than standard power available.
got a decent diff? with 255s mine's not toooo bad at 340, retune in a few weeks might be worse after that :D
Nismo diff in my car! love it!
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
