Hi all. I bought a r34 gtt in January. Was 100% stock. I've done front end exhaust 3" stainless steel and then from catback is stock and I've put a pod filter in. I've been told I should have a tune as I do each mod. Is this true and if so is there a tune I can do for the pod filter or is there only one type of tune and it will be the same price every time? I plan in getting a intercooler in the next week. Should I have it tuned before I get this installed or wait? I've been told by doing a few mods and not tuning it I can damage. The engine?
Any help would be great.
Cheers
https://www.sau.com.au/forums/topic/426097-r34-gtt-questions/
Wait till you have more mods until you tune.
That is turbo back exhaust, front mount, fuel pump and Ecu (nistune is cheapest)
A tune is a tune, pretty much the same price every time you visit ($800+)
I think what you mean by tuning after every mod, is you won't feel any difference after mods without a tune.
With the above mods and tune you will be at the 200kw mark
I have an R34 GTT and trust me the best way to get bang for your buck is to do the following before a tune:
A power goal, work out what you want to achieve before you spend a cent. Talk to other owners, tuners and club members about your goal this will save you major cash and heart ache.
Basic Mods:
Coil packs (yellow jacket or splitfires)
Air Filter (Pod or High flow Box Filter)
FMIC (I went with a Hybrid as the return flow one will restrict power gains later on)
Boost Controller (Preferably an electronic one)
Boost gauge (most EBC's have a boost gauge on them)
Fuel Pump (optional at this point but can't hurt if you want further upgrades in the future - lots of research)
ECU (either Nistune if your not gunning for big power or aftermarket ecu if your intention is to make a serious power IE: Haltech)
That should put you in the 200rwkw ball park with a tune.
Above that you want:
A tuner you trust and have faith in.
Fuel Pump (if you didn't do this earlier - Lots of research)
Injectors (sized to what your goal is - Lots of research)
AFM (z32 or q45 are popular but depending on ECU you may go MAP sensor)
Turbo (a real heap of research)
Cam Gears (only really need 1 but they make them in sets)
Cams (Pon Cams are popular)
Head Gasket
250-350rwkw
Beyond this is where you say goodbye to every pay check you make for the next few years but have a giant grin every time you turn that key.
  • Like 1
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
