Hi all , have had a few minor dramas setting up cam switching with a ViPec plug in . Is the best way to make up a table of MAP vs revs and run with the solenoid switched off up to say 3000 revs and 100 kpa (atmo) pressure ? Mine had been using a TPS vs revs table and that created drivability problems .
I set up a MAP/revs table which is off up to about 1600 revs and the off/on divide is sort of a diagonal line from 120 kpa at 1600 revs to around 0 kpa at 4000 revs . Its not really linear more a curve with its radius facing the lower RHS of the table if that makes sense .
Referencing off TP cost lots of off boost torque and fingers crossed I'll get better fuel consumption if not booted everywhere .
It's surprising how wild 256 Tomeis get with the solenoid on at very low revs , no hope of idling anyway .
Also it's set to switch off at all pressures between 4690 and 4700 revs .
Sorry if a silly question but I migrated from a PFC and you had no choices in this area , you did the idle learn and hoped it sorted itself out . Hopefully this is where I get the consumption back I had with the Apexi .
Realy like the versatility of the ViPec but it's a learning curve , cheers Adrian .
Easiest way is off a GP output then put your desired parameters (Rpm>1100, tps> 5% or whatever)
I forget which digital output it is but it is shown in the help section somewhere (in the wiring section)
Hope this makes sense. Im going from memory.
its AUX 1, set it to gp output.
Condition 1 and 2 - (OR 3)
SC 1: rpm> 1400
SC 2 rpm< 4000
SC 3 map< 180
start with this and then fine tune it to how you like it.
basically this is setup so its off on idle, then at 1400rpm to 4000rpm it will be on until the map goes over 180kpa where it will switch it off.
hope this helps
This is what I'm using and it seems to work quite well . It feels much better at part throttle for most of the sub atmo 2-3000 rev area and the 4 across the middle of the top row is an attemp to lose the closed throttle kick/buck I'm get in this area when cold . I think the cam switching and throttle closed fuel cut resumption were fighting each other in the 1400-1600 rev area .
I guess it makes sense to get the best trapping efficiency (shortest overlap period) at light loads and aside from a bit more torque in this area I could use better fuel consumption numbers too . My consumption yardstick is how far I get before the needle drops to the top line from full to the neck - which is real scientific is't it . Better than 50 is reasonable and better than 100 by the first 1/4 has been hard in the past .
A .
Edited by discopotato03
Can you post a video of how wild the tomei 256's sound disco? I have a vipec plugin myself. Can you go into a little more detail on what your actualy setting up doing.? I'm very new to all these awesome vipec capabilities lol.
My tuner did it while I was with him once , its really only around idle up to dunno maybe 13-1400 revs . Best comparison I can give is trying to make a engine with full race cams idle too slow . Wild shaking and constant stalling . You wouldn't go there intentionally if you didn't have to .
I'm guessing std cams do a similar kind of thing with the sloenoid switched on at idle .
The main issue is engine characteristics change if the solenoid switches at the wrong times , obviously too much valve overlap costs you part throttle off boost torque because the inlets close too late and the exhausts open too early . Once the gas speed is up a bit its better able to flow in the right directions .
I also look at RB25DETs as a lowish CR engine off boost and they seem to work best with conservative valve timeing for normal part throttle driving .
When my PWM table was referencing off throttle position there was no way to have the solenoid off up to 100 kpa/atmo pressure into the 2-3000 rev range (see table above) and with it on the overlap timing was to much to allow it to make best torque in these areas . It didn't really run camy or rough but it didn't feel sweet and at times a little breathless . Now its very smooth and has more torque meaning you open the throttle less just getting around . It made a big difference to the cold start and warm up characteristics meaning it drives a lot nicer initally now .
I am also starting to lean out some parts of the sub atmo pressure fuel map because I had it a tad rich in these areas looking for better part throttle performance .
I'll know later today how the consumption looks and theory suggests it should be better . Anything that improves fuel consumption (E70) and gains torque at the same time is all cake I reckon .
Cheers A .
Just as an update the consumption ended up ok but it drives better overall . I also changed the accel load table from MAP to TPS and I think thats going to work better overall too .
Do we have a Vipec/Link G4 plug in tuning thread here or do we want one ?
Cheers Adrian .
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
